14 Gauge Cluster Attempted Upgrade
I had the LT non Z71 gauges, but wanted the carbon fiber look so I purchased a Z71 cluster and got it installed. All the analog gauges work fine, but the odometer just reads dashes and the total engine hours is off significantly.
Does anyone have any experience with this or how to correct it?
Wait ... my Z71 is suppose to have carbon fibre dash. I think that might be part of the carbon package or something.
Stupid question but you are not from Canada and bought a US cluster or vice versa did you? Other than that I have no clue.
Carbon fiber is probably the wrong term, but the Z71's have some sort of pattern on the tach, speedo, etc compared to the plain black on the normal LT'S.
Nope.. I live in US, parts supposed to be from US, everything is in miles and mph.
Mine is just straight black. 2015 - HOU interior. But now you have me curious please take a pic.
Now that I think about it 99% sure this would have nothing to do with Z71 as all that adds in the mono tube shocks, under body shields and off road tuning. Should not be any interior differences ... to my knowledge.
Those are the GMC's the Chevy's are slightly different.
Yes the Chevy's have a z71 symbol similar to the all-terrain (those that are z71).
I think it's part of the All Terrain package:
Ah thank you sir. That makes more sense and might just be bias but not a big fan of that though I do like the All Terrian letters. As the guy 'who basically bought the 2015 SLE Z71+premium+loaded in the one year it was not AT pkgd' I am jelly lol
Wait so I missed out on Z71 lettering and AT lettering at the same time?
Me right now:
Did you not get your new cluster programmed? Who did the install? Most of that info is maintained within your cluster, not your truck, so the new cluster needs to be programmed with your old cluster's information.
Did you not get your new cluster programmed? Who did the install. Most of that info is maintained within your cluster, not your truck, so the new cluster needs to be programmed with your old cluster's information.
Did not get it programmed, I thought it was plug and play. Should have known better. Where/how do I do I go about getting it programmed?
You just hosed that cluster, it has to be done before it is put into the truck.
You might message GTPrix on here, he is the only guy that can program them and does them for the dealers thru a company he partnered up with. I believe he said in another thread awhile back, if the programming is not done before the cluster is installed is bricks the cluster permanently.
Cluster has to be programmed by the dealer and odometer mileage transferred to the new cluster. Old odo mi./km. information is maintained by OnStar.
Z71 appearance items for cluster, door sills, door holds, quarter panel, grille =
If you paid somebody to do the install, I would put it back on them to correct the situation. If you just bought it from a dealer, I'd have them fix it. If you bought one off ebay or something, you might be SOL.
Not that I have experience doing so, but I do know electronics and data pretty well. I would think there was a way to 'flash' the unit if anything and then 'start over' if not I do not understand why such a thing would not be included.
Would that be a legal/regulation thing mandated that you cannot reset it because of scams or what not?
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,693 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
