did you set it at 8 to avoid rubbing? Mine goes on next week i hope. Doing 20x10 -19 was thinking i would set it at 7 so i can clear a 7' door.. hopefully
I have over 10,000 miles on it now and no issues what so ever, so far so good....everyone that rides in it can't get over how good it rides being lifted, I'd go with this same lift if I could do it all over again
how are the tires holding up after 10k? My next set up will be very similar to yours, but with 37s
Still set to 8" and 35s?
Yep! The only thing I regret was not going with 37's, not ready to get into changing the gears and all yet but I do think this lift would look alot better with 37's vs 35's, but as far as quality it's top notch no issues
It's just the look I was going for really, didn't wanna cut or remove the front valence because to me, Noone get offended this is just my opinion, I think trucks with the front valence removed just looks a little unfinished, not a fan of all the bolt holes showing....also not a fan of the front sitting lower than the rear and set at 8" in the front with the factory 1 inch block and the 6 inch block that comes with the kit on the back the truck sits roughly a qaurter to a half inch higher in the front, it's a very aggressive look in my opinion, to each his own but the way mine is sitting is exactly what I was going for, as far as the rims you can look back at my pics but mine are 22x10 -24 offset so I'm pretty sure your will be a similar look to mine
Think set to 9" and 37x13.50 on an 18x12 I'll have major issues?
Holding up well, I'm very analysis about rotations every 5000 miles, so tire wear has been very minimal, I would love to see yours with 37's tho....as soon as I need a new set big orange with be sitting on 37's and re geared
No I think you will be good just make sure you get a rim with enough back spacing to clear that lift knuckle....I could clear 37's on mine easy with it set at 8 so I really don't think u will have an issue at all...35's are borderline almost too small with this lift in my opinion, but I hear when u go to a 37 you need to make more upgrades as far as gearing, control arms, etc. To keep them from wearing out everything too fast
Yeah gearing definitely. Control arms will come no matter the route I go. Also full leaves in the rear doing away with blocks.
Watch the offset that's the only thing. I have a -44 mm offset set at 9 with a 1.5 inch body lift and I still had to trim the lower valance. Also, in reverse at full lock I rub the inner, lower part of the fender flare as well. I'm running 20x12s with 37x13.5r20 toyo mts. I may not rub if I didn't have the fender flares.
Edited by Blk2015gmc
Got pictures? What's your back spacing with the 20x12. Also tire? Im looking at the cooper stt pro 37x13.50r18 and the fuel hostage 18x12 -44 4.75" bs with that lift set to 9"
I already removed the front lower valence before the ditches on the farm did it for me.
Very nice. Have any early predictions on how far they'll go before needing to be replaced? Also what is your driving style like? Just trying to wrangle up some good reviews of the STTs.
Oh yea, mine will definitly be 37s. Most likely 37x13.5x20 on 20x10. Or MAYBE x12.
- Mike
IG: @BlackPearl_Edition
What tool box is that?
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 653 Guests (See full list)
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
