New from Vegas
Gecko50
Hello from Las Vegas. I have had a 1999 dually gasser, followed by a 2014 GMC Diesel Denali... and for the last 3 weeks I traded the 2014 for a 2016 GMC Diesel Denali. Love the 2016
Here is the 2014 hooked up to our race trailer.
Thsi is a shot of our 2016 Denali, 3 weeks old. This Friday they install the "Pop up goose neck hitch" Cat wait
Chuck
PAE
What's in back, chuck? Could be a few cars or a really long alcohol drinking one... :)
Front half living area, full out with AC, shower, pottiw and a queen size bed. Back half has our 1987 mustang drag race coupe.
Welcome! What part of town are you in?
Sent from my Vortec-powered Droid Turbo using Tapatalk
I down by Nellis and Sahara... east central I guess.
Chuck
PAE
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
