Winjet Headlights w/DRL and LED Taillights
Just got the winjet headlights installed, wondering how you adjust the beams? Thanks
There are hex head bolts on the back of the headlight housings that you can adjust either with a socket or a Phillips head screwdriver. I used a socket to do mine.
It's easiest to start on one side and move the adjusting screws one at a time so you understand what each direction does and then make your final alignment.
  • Replies 112
Awsome, thanks
Awsome, thanks
Sure thing. Show us how they turned out with some photos when you're finished.
Il be sure to add some pics once I get them adjusted better, but just wondering do you have a blueish line at the cutoff? Or is this normal in projectors?
Yes, I have the the blue hue at the beam cutoff as well and it's my understanding that it's normal for projector beams.
  • 1 month later...
I just got these housings as well. Do you know if I can change to h7 LED easily?
I just installed the Anzo's. It also takes a H7. I installed the Xenon depot xtreme LED kit and it dropped right in. All of the extra stuff including the Canbus adapters all fit inside the housing.
I did HID on the high beams.
Ha, i am like a reverse clone of you with my Anzo headlights. I did the morimoto HID for lows and Opt7 LED for high beams. Are you liking the Xenon depot extreme LED's? Is the color more white than blue?
Yes they are white white. They are 5700k And 2000+ Illumines. They make the Sylvania Silver Star Halogens look yellow.
They also offer a HID in any color temp you want from 3000k to 8000k.
The High Beams are H3 and all I had found was HID when I was looking. I got the 8000k HID for my high beams.
0DB6C1CF-2FD7-438E-8137-39E1ADC2EECA_zps
That looks killer! Nice set up ssmith10pn!
How is the LED at night through the projector? A lot better than LED in reflector housing?
I am very happy with them.
I intend on shooting a video very soon. I put the LEDs in my friends 2016 F150 that doesn't have projectors and he said they were better than the halogens but not as good as my projectors.
Anyone else with these have any rotational alignment issues? I noticed in OP's cutoff pics, the steps aren't quite lined up rotationally. And this is an issue I had with my mustang projector lights and had to send them back
    Sdid
    Sdid
  • Who's Online   3 Members, 0 Anonymous, 1,414 Guests (See full list)
