Winjet Headlights w/DRL and LED Taillights
I had the OEM halogen reflectors in my '15 double cab LT All-star package and was wanting to upgrade to projector beam headlights like what's in the LTZ package. I did some research and received Winjet's projector beam headlights with DRL as well as their LED smoked taillights.
Headlights: SKU: WJ10-0382C-04-0914
http://i1motor.com/headlights/chevrolet/silverado/winjetr-2014-2015-chevyr-silverado-projector-headlight-with-double-led-light-bar-drl-black-clear.html
Taillights: SKU: WJ20-0383-05-9688
http://i1motor.com/taillights/chevrolet/silverado/winjetr-2014-2015-chevrolet-silverado-tail-lights-black-smoke-1942.html
Installation:
Installing these is a pretty simple job. The headlights take a bit longer than the taillights because you have to remove the plastic radiator shield under the hood, the grill, and the upper bumper piece. You also have to tap into the purple wire in the factory harness to supply power to the DRLs. You'll only have to tap into one of the harnesses as Winjet supplies an extension that'll span the gap and power both of the DRLs in the headlights. It took me about 2.5 hours (including time to shoot the video) to install the headlights.
The taillights can be installed in less than 30 minutes. Just remove the two screws on the inner sides of the lights and remove the housings. The factory harnesses will be used and the install is plug and play. You will have a total of 4 relay controllers included with the LED taillights that can be mounted via screws or adhesive (I chose the included adhesive).
Fit and Finish:
I'm very pleased with how well they fit. I have no complaints whatsoever about the fitment and they look great. The projector beams need a bit of adjustment, but that's typical with any new headlight. The daytime running lights show up great at dusk/night, but aren't nearly as bright as the factory '16 LED strips in the daylight.
Pictures:
FDE7C1F0-6AF3-41F9-9B3D-BDB439A746D9_zps
B2E0A5FE-2027-4E58-80A4-DF7486A0AD82_zps
  • Replies 112
Very cool. Any photo of the tail lights?
Yep I think you viewed the thread before I was finished posting.
Nice video and write up! Those headlights have gotta be expensive. Lucky you for receiving a "review" set.
Thanks. They're in the $400 neighborhood depending on where you buy them from. Still significantly cheaper than the factory option.
how is the light output on the headlights?
I like them but if I may make a suggestion if you are into it and trying:
Contact GEN5DIY they made me a relay harness for my Spyder headlights which kills the headlamp and powers the LED DRLS via a tap to the #50 fuse (o2 sensor only on when truck is running) during low voltage ie) daytime. Headlamps & LED function at night ie) high voltage. I am super happy with the results and is completely plug and play so can always be removed! My OnStar does give me a warning that I should check headlights but it only a warning so I just ignore it, no biggie since they are being killed during the day.
Since your OEM headlamp harness is 5 pin like mine and you are basically just tapping to supply the LEDS with power I am sure this or something very similar would work for you. Cost me about 165 smack-a-roonies on top of my lights. The people at GEN5DIY are awesome and worth asking IMO. I am still waiting for the dang matching Spyder taillights to come off backorder .... 7 more days ugh!
I can't complain. It's not super bright like LEDs or HIDs, but they do a good job in my opinion. I still need to adjust the height of the beam, though.
Thanks for the heads up I'll have to check them out.
I doubt I'll change them because I'm pretty satisfied with how they function out of the box. Plus I don't know if I see killing the headlamps as $165 worth of changes, but the concept is pretty cool.
not gonna lie... that looks pretty sweet!!!
Thank you sir. I'm really happy with them.
Do thisThis is how I did the relay
Low Beam + coming from harness to COM, NC to DRL, NO to Low Beam, and one of the coil to + from parking lights and the other to chassis ground. You'll need to use one on each headlight.
Can you get some night time cutoff shots of the projectors? Wondering how they look output wise.
Are these what you're looking for?
D09F15D1-D68F-4B82-BF2D-7514948489EB_zps
B065F1BA-6418-4E6D-A21C-F01C4C321C2A_zps
CDE123E5-3B4B-4CF7-B239-4C8B8EEF9B6F_zps
0A200241-66D2-4486-ACB0-2A63AE125566_zps
B8F174C3-BD75-4C4C-96EA-F9CDF0652E5C_zps
E197F414-7E00-4DBA-813C-0C79C4137683_zps
3B9A2607-CC0F-40ED-B63B-B28976DCC628_zps
F7A44825-C5B2-4F09-B695-7C2AF441250C_zps
FEC4C799-F236-490B-8CD1-853C448929DE_zps
4A6874FD-1A50-4202-9DEA-B3FFB19DB366_zps
2EBC2E69-DC97-4A42-8E05-8081317FFDAD_zps
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
