2016 5.3 6 speed. Do these trucks have learning transmission programming that adapts to the driver? I've gone easy the first 2 months and now the tranny seems much less responsive and resistant to downshift than week 1. If it did learn my driving, if you stomp on it for a few days will it downshift quicker?
The word from the dealers is that there is a learning process involved with transmission programming. That may be the case in some small way. There may be some routine that fine tunes the base program. The funny thing is, I didn't experience any learning mode when I applied a Diablo tune to my transmission. The change was immediate and for the better. So I'm kind of skeptical about this "learning" mode thing. I'm not sure whether the transmission is adapting to the owner or vice versa. Anyway, to address your question directly, don't baby the truck. Drive it like you normally would and after 5000 miles or so, if it isn't right take it in for service. Trust me, you wouldn't be the first.
The 6 speed in my '14 acted weird in learn mode, but after about 2-3,000 miles it started to act fine. Since then it's been perfect. Some can take a little longer from what I've read.
There are some adaptive tables in the TCM that take some time to fully set in. I don't think those tables can be wiped from a battery pull, I believe it takes using a Tech II in order to clear them.
It seems that some transmissions are unteachable. Especially ones assembled wrong or with defective components. :rolleyes:
  • 5 years later...
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
