Sport Bar Mounted Light Kit Part #23415421
Oldbay
I actually have this one for sell, my truck didn't come with the oem fog lights so it didn't work me so I ended up using a toggle switch and I have this for sell.
I'm assuming you sold this but did you happen to get the part number for it?
If you truck came with the fog lights from factory it is a plug and play if not you might have to hardwire it.
found the switch from the same seller with a back shot. would that number at the bottom be the part #?
http://www.ebay.com/...s-/182140355290
I may have found the part # 23458492 for with fogs. here is a link to an online dealer http://www.gmpartsdirect.com/oe-gm/23458492
harness part # 23415425 with fogs for the colorado. here is a picture
the light switches look the same in the colorado, so the harness may be the same. i got it from this ebay listing http://www.ebay.com/itm/23415421-GM-Sport-Bar-Mounted-Lamp-Kit-For-Chevy-Silverado-Colorado-w-Fog-Lamps-/182140355290?hash=item2a686942da:g:JJAAAOSwnLdWtREG&vxp=mtr
sierra kit part #23415424 this is with fog lights, part #23415423 is without fog lights. now on to search for the switch and harness.
The 2016 Silverado and Colorado both list 23415421 as the part number for the light kit (for trucks with fogs) so the switch and harness should be the same for both.
Sent from my Nexus 5X using Tapatalk
Reading the the Colorado forum post from the link it sounds like they are requiring a BCM program for the switch and lights. Did yours require a program? Did they provide any instructions? If there is programming required I'm betting a lot of service departments Wong assist and all this work is for nothing. I would hate to spend a couple hundred bucks for switch and harness only to find out I couldn't use them.
  • 1 month later...
So let me wrap my head around this and ask a couple of questions. My All Terrain X has the sport bars. So it's just plug and play correct. No reprograming of anything? Can I just use the wiring that is there and connect it to an aftermarket light strip that I find? Can't see spending the kind of money GM is getting for 2 little lights. I'd rather find a strip.Thanks!!!
  • 5 months later...
You are 100% right. There's no doubt that a 50" roof-mounted LED light bar would be more effective. Neither of which is street legal---that I know from my Jeeps. They will ticket you in Maryland if you ever turn on those AUX lights.
I'm going to have to think this one over...none of these lights are cheap.
this is a 42 inch lightbar
Is anyone indtalled kit PN 23415422?
What comes with it? Parts, subparts? Instructions? How lights bars are controled in the cabin? Any pictures?
Thanks
