Dash gauges or alternator
dbmorts
I drive a 2014 Denali 1500. When i first got this trk, using the four gauge cluster in dash, the volt gauge would always read above 14. 3 volts (approx). Every once in a while the volt gauge would drop to around 13 volts(+/-) . I reported this to the dealer, was told everything is A OK. As time has gone on, I have now noticed the voltage gauge reads around 13volts (+/-) most of the time and goes to 14.3 volts less amount of time than the gauge stays on the low side. Kinda a reversal of when it was newer. I reported this to the dealer, they checked it said no engine light, charges as per specs. I find it kind of hard to beleive over a 2 and a hlf years, the battery would require less charing. Has anybody else experinced this and has it been reported and what was the determination? any response would be appreciated.
I'd say it's probably normal. Does it change when you turn on/off the AC? There should be a difference in the volts when more load is put on the engine. You also say that the battery is 2.5 yrs old which is probably why you're seeing the volt change. Most of the batteries in these trucks only last about 3 yrs if you're lucky. At least that's what I've seen on my last truck.
Sent from my SAMSUNG-SM-G920A using Tapatalk
It is normal, the battery maintenance module that GM uses now only charges the battery when needed. Cuts down on over charging and also frees up some power in the name of fuel mileage since the power isn't being used to turn an alternator that is in an excited state.
Being mechanically inclined, a person would think that the older the battery gets, the longer period of time and more charging volts it would be required, even with the battery maintenance module. One issue that would prevent that was that if the battery were bad and not accepting the charge from the system. I guess I am going to hook up a mechanic old fashion volt multimeter and monitor for a few trips. I want to record the voltages a little more accurate than the guessing you get from the gauge. Can a GM certified assistant comment on this, maybe explain the charging system battery maintenance module. Thank you
No they wont, they know nothing of how those systems work. The manual talks about it as well if you need info. Otherwise it is what it is, there is no way to change it since the charging state is controlled by the BCM computer.
You can install a brand new battery in your truck and if that battery sat for some time on a shelf and is partially discharged, you will see your gauge indicating 14+ volts for some time because the battery needs to be fully charged. Once the battery receives a full charge, the voltage gauge will drop to 12 Volts of so. If you are still concerned about the health of the battery of the alternator, both can be properly load tested by a competent outfit at a nominal charge.(the main challenge is finding that competent outfit)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
