Boss Coilovers 0-3" of lift
HaloLifts
  • Replies 133
Ordered my HaloLifts Coilovers last Friday, and received them this morning around 10:00. Got straight to installing. I installed them with one spacer making 2.5" of Lift. (These Coilovers can go from 2", to 2.5" with one spacer, or 3" with two spacers.) I have never ran FoX, or any other brand Coilovers. However, these are amazing!! I'm super happy with my choice as of right now, and don't see that changing. I have put about 50 miles on them so far. I went straight to Discount Tire and had Cooper STT Pro 295/55R20 put on stock GMC All Terrain wheels. No rubbing nothing, and I probably could have gone 295/60.
What type spacers are used for the additional lift? Got any pics?
It's basically an aluminum spacer much like a leveling kit. Instead of trying to adjust the Coilovers yourself HaloLifts has these spacers available.
I will say this I am completely amazed at the ride quality with the Coilovers. The truck rode decent before, but now it's night and day different!
Well someone has to make the shock body. And I don't think it's a bad thing if it's Bilstein
This was from Toytec (regarding Tacomas). When you go to Toytecs website- the product is just called- Toytec Ultimate, so in my mind rebranded. Its splitting hairs- so no biggie. Now I know what you are offering is not a 'rejiggered' or 'rebranded' 5100, which was the crux of the question!
I contact Toytec about thier lifts within my budget and threw in the Radflo set up too and this is what they had to say:
It sounds like you are on the right track and i don't think you can go wrong with any of those options. I will highlight some differences for you between those kits
Ultimate Lift: This is already assembled and uses Bilstein shocks. The front coilovers have a threaded sleeve that fits over the shock which means you can adjust it from 1-3 inches of lift and anywhere in between. This kit is works really well if you are planning on adding weight in the future since you can turn the adjustment up once you add the weight and not have to disassemble the front shocks and/or swap to heavier springs
BOSS System:
The BOSS system is pretty much the same as the Ultimate with the exception of the front coilovers. We build that shock ourselves and we tweaked the valving to ride better and have more control over bumpier terrain. The shock also has a larger diameter shaft so there is a significant increase in strength and it is rebuildable as well. Instead of a threaded sleeve on the shocks like in the Ultimate, the shock body itself is threaded which is easier to adjust.
The Radflo's are more of a high end race style coilover. They will perform better under high speed offroad situations but they do require more maintenance than the Bilstein's that are used in the Ultimate Lift or the Boss kit. Bilstein's are a maintenance free design where the Radflos require rebuilds periodically. The BOSS coilovers are rebuildable but do not require it as often as the Icon or Radflo setups would. However it all depends on how the truck is used. If you truck sees a lot of heavy offroading, the Radflo setup would be my recommendation. Otherwise I think the BOSS or Ultimate would probably be a better fit.
Let me know if you have any other questions
Thank you
Dylan
Sales and Tech Support Manager​
Very nice looking truck Tony!!!
Thank you Alex! I'm super happy with the results and have received multiple complements on it.
The dealership I bought the truck is interested in the Coilovers. I have passed your information on to them.
Install day. A small shop close to my house is doing the install and an alignment for $140 + tax.
One side is in.
Driver's side.
So far so good. 2 inches of lift. Check✓. Dampens way better than stock. Check✓.
What about steel vs aluminum control arms. Does that matter, I have aluminum will I still get two inches of lift? I heard people having problems with fox coilovers not getting the advertise 2 inches of lift.
Would adjusting the coil for more lift or putting the spacer in be a better option?
Aluminum or Steel UCA doesn't matter. You will get 2" of lift without using a spacer. The Boss shock is adjusted/set up at the near max where it still rides great and functions as it should....so it would be a lot easier to just add one or two of the included spacers to get additional lift.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
