Military Grade?????
Likarok
I could be wrong. I'm just thinking that Ford does use a Military grade aluminum, as in material. But, I think they use a thinner version of it. So maybe since it's the same material they can legally say it's military grade, it's just not military standard thickness. It's like different thicknesses of bullet proof glass. At a very thick version of it, it may only stop a 22, but nothing else. The material needs to be thicker for bigger and/or faster bullets. I just figure that's the same idea. Again I could be completely wrong, just how I've thought about the whole thing.
I do know Ford guys and others are saying that people that really use the bed like that has either a drop in bedliner or a roll on or spray on bedliner. But, I think all of the commercials about the beds are just showing how much tougher the bed material itself is stronger than Ford's.
  • Replies 32
I am sure it would be very helpfull if they linex the bed from the factory. Personally i wouldnt buy aluminum body truck for a number of years to see how real like take its toll on them
Sent from my SM-G920V using Tapatalk
Every truck manufacturer has a spray in bedliner now. Not Line-X but regardless I'd never own a truck without a spray in liner of some sort.
I mean as far as the test goes, linex is pretty strong it very well may make the thin bed usable. The largest problem today is all the people who own a truck and dont use it as such! I looked at a ton of used trucks most didnt seem to ever have a ball put in it, and didnt have a scratch in the bed
I always get a kick out of when folks and OEM's use terms like "military grade". That has no meaning whatsoever. Any of us who have done time in the bush know that everything we are using was done by a bid contractor at the lowest cost they could do it at. And back in the day when I was a young lad stumping around in the bush, anything "military" was not very much welcome back in the world. Only now that we have come back to an appreciation of military folks, OEM's and others come out of the woodwork touting this "military grade" crap as a marketing tactic. There is no such critter as military grade aluminum except in name only. Aluminum stock is rated on industry uniform scale.
Where this all falls apart is that you cannot have a similar thickness of aluminum and steel and expect the same result. Steel rims are much thinner than aluminum rims. But even with the thicker aluminum rim, the weight is less than using steel. That is why most commercial trucks use Alcoa aluminum rims instead of steel. For the aluminum bed to have the same strength as steel, the thickness would have to be more. From what I am seeing, the thickness is relatively similar, so the aluminum bed is not going to be able to take severe strikes and hold up like the steel one would.
Ford does NOT use "military grade" aluminum. They use a 6000 series alloy which is where the military grades start out too but from there the metallurgy and processing is drastically different. They had to use "Military Grade" in the title because if they just said "Aluminum" people would think of soda/beer cans. Read this interesting letter in the current SAE (Society of Automotive Engineers) magazine from someone who worked around military aluminum for a large part of their career (reprinted from SAE so all credit goes to them).
BTW - I don't know the person who wrote the letter but I work in the defense industry and know for a fact there is a big difference in the aluminums used.
SAE Aluminum.pdf
SAE Aluminum.pdf
SAE Aluminum.pdf
SAE Aluminum.pdf
Only to those that have no experience with aluminum. There are great applications of aluminum in vehicle body use. Heavy commercial trucks and trailers use aluminum extensively. I have been shocked that the auto / pickup world has taken so long to use it more.
Ya but if you think about it, 18 wheelers and the trailers use aluminum and fiberglass in the right places. All of the box trailers or box trucks I've been in the floor is wood and not aluminum or any kind of metal. I know the roof and walls of 18 wheeler trailers are thin. If it was up to me, even if the whole pickup was an aluminum body I would still want the bed floor to be steel.
  • 3 weeks later...
Most guys shrug off the aluminum bed holes. I actually DO use my truck like this. I hope GM doesn't use aluminum for the bed.
For Ford to go with such thin sheet metal is embarassing. They push the "Built Ford Tough" tagline but their bed doesn't meet that standard. In the lead-up to the release of the 2015 F150 they were putting out tons of marketing videos where they showed F150's being loaded just as rough as the GM bed test. Military grade is a meaningless tagline. Everything in the military has a spec or grade. Great marketing team at Ford though.
During the GMT800 program there was a concept for a composite fleetside box. The box sides were to be a similar mat'l as the stepsides mounted to a metal structure. The inner steel panels were to be replaced w/ a 1 piece part like the typical box liner.
I don't know how much a spray in liner would protect an alum' box floor from impacts.
It wasn't just a concept - GM sold it for 2 years. It was called the "Pro-Tec" composite bed. It held up really well but didn't sell since people were afraid of anything that wasn't steel. Also you didn't need a bedliner with it and the dealers were losing out on bedliner upsells so they weren't ordering stock units with the composite bed to sit on their lots. GM discontinued it in 2002.
Were those the boxes w/ the raised "Chevrolet" on the tailgate & "different" taillights?
Having been employed by Uncle Sugar for over 29 years, the only "military grade" that mattered was the PAY grade.
And it's a great retirement!
Thank you, taxpayers.
Yes those were the ones!
A big seller like the QS4 4 wheel steer option, which I THINK added 3,000 bucks to the price. When we were making some tooling for the QS4 I said it was too bad that the money wasted on this wasn't spent on putting a solid steering axle in the HDs. Might've gotten some sales that went to Ford & Dodge. In '05 when I was in Alberta & British Columbia, the work trucks were all Fords & Dodges, I don't recall seeing any Chevs or GMCs that had been upfitted for work.
I think I've seen TWO of those Pro-Tec boxes over the years & maybe 10 or so of the QS4.
The chatter about the plastic box was just that. I guess production was just in 1 of the 4 plants so that's why we were never involved w/ it.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 859 Guests (See full list)
