Checking in from Illinois
lineman74
Hey all, new to the forum but not GM products. Currently in the stable: 1999 Silverado Z71. 3rd door with plenty of rust, 2007 Yukon XL (wife's ride) and now a 2016 Sierra 1500 ATX. In the process of modding the new ride. Just ordered a complete set of Bilstein 5100's. Waiting to see the height after install before I put tires on.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
