8.1 with excessive oil consumption
I have a 2005 fleetwood motorhome
8.1 vortex 27k miles
No signs of oil leaks
Not blowing blue or grey smoke
Power is good
I'm using up 2 quarts or more within a 200 mile trip.
Any ideas ???
You say it is NOT blowing blue smoke? If not burning it then it is blowing it out going down the road. Check the PCV system first.
be sure its using enough fuel.
lean can suck a big block.
those need 11AFR..
I see you are in california.
I bet its a hypermiler. :)
I'd bet dollars to donuts that the valve seals are bad in it. GM at one time used just cheap plastic umbrella seals. We always installed the TRW ones that were more of a nylon type material and they really helped on oil consumption. Hope this helps. :jester:
