4 minutes ago, Nasty said:
It's your turn
I know I keep saying I'm gonna do it and I will eventually! ?
I added this same post to the lowering thread.
So when I originally put the flip kit in I had the rear hangers set at the 6'' position and used my 2'' drop shackles to raise it back up to 5''.  I decided 5'' was low enough in the rear and wanted to to get the drop shackles replaced with the stock shackles, so  lowered the hanger to the 5'' spot and put the factory shackle back in.
Now it in theory it shouldn't have changed the rear drop, since both were set to 5'', but I feel like the truck is sitting an inch higher in not only the back, but also the front now.  I'm pretty sure it's only in my head, and I measured from floor to fender and I'm 34'' front and 35'' rear,  and I could have sworn I was 33"/34" last week.
Either I'm going crazy or now I want it lower, But the front seems awfully high now.  I'll take it out tomorrow and take another side shot pic in the same spot in my driveway as I previously did.
Here's how it sits now
Edited by qwank
It's all in my head, it appears to be the same.  I tilted the camera a little this time so it doesn't look like I'm going uphill.
trucksun.thumb.JPG.13cb93e31fbb7e290fc237ee7f42f94a.JPGtrucck2.thumb.jpg.170d0615c45b581562dcf17ba11f9788.jpg
Beautiful truck.  So, if I followed your thread correctly, all said and done, you're at a 3/5?  I just bought a 2017 1500 LT Crew Cab with 22's.......can't decided between a 3/5 and a 4/6.  I like the 4/6, but don't want any rubbing issues.
It's supposed to be 4/5, but I'm not sure I got a full 2'' out of the drop spindles. I never measured everything exactly before and after.
EDIT: Looks like I'm closer to 3.5/5
Edited by qwank
  • 5 weeks later...
2800 miles.
took the 10mm ring out of the right side shock and it got rid of the lean and both sides are the same height now.
Also dropped the rear down to 6, so altogether I am pretty much 4/6 now.  Installed offset upper control arm bushings and set my alignment.
  Did my second warranty oil change too since I had the truck in the shop.
2960 miles
OK, suspension is all sorted out, time to move on to something else.  Next up is the stereo system.  I have the I06 radio with UQ3 speakers. Non Bose obviously as it isn't available in regular cab.
The stereo upgrades will be done in two phases. Phase one is new speakers and door sound deadening, and phase 2 will be DSP (going 4 way active), amps, subwoofers and cabin sound deadening.
So I'm a huge Alpine fan and I've used them almost exclusively in every vehicle I own.  I also have a a collection of vintage Alpine radios and amps.  So I was excited when they came out with a custom fit speaker system for our trucks.  Only problem is I wasn't paying, 1000 bucks for them.
  A set of woofers and mids with the passive crossovers showed up for sale online for a fraction of the price of the kit, so I grabbed them and added some SPS tweeters I had already.  Since  I didn't get the custom dash brackets that hold the tweeters, I just flush mounted them into the door trim, which I think looks cleaner anyways.  I realized I didn't have any tweeter crossovers so I'll have to wait Until later this week to finish this up.
Here's some pics so far:
Alpine 8'' woofer next to the stock 6x9
3'' mid next to the stock dash speaker:
mounted in place:
Tweeter mounted in door. There's a mounting stud and bolt for the mirror in this area. I just cut the stud down to the bolt and had plenty of clearance:
Doors. I didn't go crazy with the deadening this time. Usually I will cover the whole inner shell but it's a pain in the butt when I need to get back into the door later to replace window regulators and door actuators.  So I made sure all the bolts and nuts weren't covered and the openings were accessible still. The outer panel is covered as well between the door braces. (not shown)
Edited by qwank
Looking great qwank!!
I need to start my audio. The stock crap sucks ass
I bought this JL Microsub about a year ago, because it's compact and fits behind the seats and console perfectly. It's It's a powered sub rated 500w at 1/4 ohm which is kinda crazy. I'll probably be using still unless I decide to go with something with more power.
Edited by qwank
On 6/3/2018 at 6:18 PM, qwank said:
I bought this JL Microsub about a year ago, because it's compact and fits behind the seats and console perfectly. It's 500w at 1/4 ohm which is kinda crazy. I'll probably be using still unless I decide to go with something with more power.
.25 ohm? You may have that mixed up.  Any (store bought) amps aremt stable at that.    Maybe the writing internally is wired like that but you will send your amp into protection
Nope,  copied right from JL's website:
Amplifier power: Built-in DCD™ Class D amplifier (500 W @ 0.20 Ω)
Nominal Impedance: 0.20 Ω
That's crazy.  That super low impedance.
I know. The subs are actually 0.4 ohms each, wired to 0.2 ohms.
ACP208LG-W3v3
Amplified Subwoofer System with Dual 8W3v3-0.40 Subwoofer Drivers, Built-In 500W Class D Amplifier, Black Carpet - Ported Enclosure
http://www.jlaudio.com/acp208lg-w3v3-car-audio-microsub-amplified-subwoofer-systems-93331
Edited by qwank
ACP208LG-W3v3
Now I understand. It's a built in amplifier. Because every jl amp I've seen is no lower than 2 ohm.  But its built in.  Got it now.
    MASONV88888888
    MASONV88888888
  • Who's Online   4 Members, 1 Anonymous, 950 Guests (See full list)
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
