To keep my lease or buy new
Hey guys, just looking for some advice/opinions. I currently have a 2015 GMC Sierra Elevation Edition. My lease is coming up in April next year. I'm caught between a rock and a hard place as to keep my current truck and buy out the lease or purchase new. The buyout of my lease will be about $25000 (I am in Canada keep in mind). With the financing going to be 5.99 percent the payments to buy my current truck out for 5 years will cost about 580$ monthly. Looking at the other side of things I can get into a brand new 2017 Sierra with a few more options for about $615 a month , but over 7 years vs. 5. I just don't know which route is a better way to go. New truck with new warranty but pay for it for 7 years, or 2 year old truck and pay for it for 5 years. If any more info is needed please ask. Thanks.
how much have you already paid for your leased truck?
I would consider if your total investment in the existing truck (Lease payments + 34,800) (which is $580 x 60 months) is a better deal than what you would spend on the new one (51,660). remember your lease has paid off a percentage of the truck already. and don't look at the sticker price, but rather the sum of the payments.
neither is necessarily cheaper. it comes down to how much you like your truck, vs how much you want brand new with a few other options. and don't forget, when you buy a new one you will spend even more money customizing that one.
no significant changes? I'd stay in the old one.
my dad did the lease thing.
I identified some engine changes, and the DRL stays on now with the blinker for the 16-17.
I go all the way back to the first of the obd2.
Just to take in the old iron.
Some get addicted to payments. Weird disease. :)
If you like to give money away keep leasing. Period. :happysad:
  • 2 months later...
In the same situation right now! Thinking I am going to buy out my lease. Then when I find a 2017 or 18 truck I really like I would trade my 2011 crew on a new one.
I was thinking of getting rid of my lease truck at lease end because it got hailed bad a month after I got it in 2014. But they did such a good job of fixing it and I have never seen a reg cab short box as nice as this one so now I am leaning towards keeping it as a daily driver. And have some fun with it putting some goodies into it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
