UPDATE:
Part Numbers
Heated Steering Wheel: 23278632
Clock Spring: 23193462
Removed the heated steering wheel but left the clock spring in - Installed my original steering wheel to the new clock spring to see if the back lights work, and they do... Confused to the max.
At this point, I think my game plan is to remove the switch assembly on the new steering wheel that manages the cluster and 3D print a blank insert to go in its place.
As to the heated steering wheel portion - I will reinstall as I had it, where it was receiving constant power and not shutting off, but this time will add a switch in line and mount it near the head light knob. I'm done messing around with wiring and what not.
Lesson learned - never buy a base model vehicle... Nothing but trouble when trying to customize or add higher trim upgrades. Honestly ridiculous.
If your truck has a vacuum line, that means it has the fuel pressure regulator on the fuel rail. This also means there's a inline fuel filter along the inside of the frame rail, below the driver's seat. Maybe replace that and check FP again/.
