Sport bar - pros and cons
Donstar
Best one I have right now, too much ice on things to get any right now
  • Replies 45
Thanks.
I actually like that even better without that side plate on. As long as you got everything secure properly so it doesn't rattle/vibrate, I think it looks much better the way you have it.
Thanks.
Originally, they came off so I could take pics of the metal sides to see if a guy could fabricate another set with my own design in them. He couldn't do it and I never put them back on. I've decided I like them better off also.
Looks good..
Sent from my SM-G930V using Tapatalk
I think with the side plates on it feels too "Avalanche-y" for me.
I agree they look good with the sides off but have a certain appeal either way. Your black truck with black wheels and HD tires looks good with these bars. Are you getting some practical use from them? I worry that with my stock, city driving truck this setup would look out of place.
Not my cup of tea, but if you like how it looks, and they're giving you a crazy good deal on it, I'd say pull the trigger. Especially if you have plans on needing a place for additional lighting at some point in the future.
And you could always resell later for profit...
They look good on the right truck...Dodge had a brushed aluminum version of this and the side bars at one point.. looked good on my short/standard, but looked rediculous on a long bed and good sometimes on a quadcab with the right color combination.
Looks like they won't work with a tonneau cover.
Depending on how bad you want it, I have seen some postings of people notching out their tonneau covers. Not sure how well that would keep out the water or impact functionality though...
These sport bars sit on the rails, no?
I've seen owners take the cover to a marine shop or an upholstery shop and have the notches put in and the cut edge finished so it looks good.
You are correct. Sorry, that's what I meant. They notched out the railings. Still, I don't see it being as water-resistant as before. I have a BakFlip and those channels are like little gutters. Notching them would drain the water back into the bed of the truck.
I didn't see the lip on the inside in that picture the first go around...that would pose a problem. I was thinking they sat on and secured to the top of the rail.
Yeah, no go for me with a cover.
I would say it doesn't look anymore out of place than any other rig that has been heavily modded and a street queen.
There is a thread on here where guys have successfully added covers with these bars.
  • 4 weeks later...
I've had my bed sport bar on for a couple months now. I really like it. I have noticed the rattle up top but yeah it can easily be fixed as stated earlier. The way it bolts up you can tell it is definitely just for decoration. You can tell by the weight of it alone. But I am super impressed with the quality of it and the finish.
Still putting off buying a bed cover to accommodate the bar but it has been done and several covers will work. I also don't notice much of a blind spot because the rear headrests are usually there anyway and the tint doesn't help anyway. Never relied on that view out of the back windows anyway.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
