Amber bulbs for the tail lights ?
Mogbil91
I just had an idea of replacing the red tail lights with amber ones
To give my 2016 sierra a personal touch
i am not sure how would it looks since the housing is red ?
Any experiences or ideas ?
likely a bad call
i'm not sure where you are but pretty much everywhere your tail lights/bulbs have to be red
orange is for the front markers and turn signals
i had a cop give me a tough time once becuz on my old truck i had added driving lights (they have white for driving, amber for fog and some tiny blue bulbs that come on with the daytime running lights). he went on that i'm not allowed to have blue lights on my truck since they are only permitted on police vehicles and someone might mistake me for a cop. he was nice enough and only gave me a verbal warning so i told him i'd disconnect them - i never did. what i really wanted to do was ask him was if he actually believed that someone would mistake my 1989 chevy 4x4 standard cab, short box , stepside that's jacked up 6" and riding on 35" bfg mud tires for a police vehicle - but like i said, he was nice enough about it and i didn't feel like pushing my luck.
Funny you should mention that! I went to court for this and you should have seen how the judge put that RCMP down and even called him an illiterate. If you look it up in the annexe of the rule book it says you're not allowed flashing blue or red lights in the front. Also to be considered a light they need to be of a certain intensity.
To the OP if you are considering putting amber bulbs behind the red lens it's a waste of time because it will not make much of a difference in the hew. It will remain red. But were you to put blue bulbs in there you would get a nice purplish tone.
I wouldn't alter the color of the red tail lights.
You could argue the letter of the law all you want. If a cop sees a tail light that is not red, or a light he thinks is the wrong color on the wrong end of the truck, he can still pull you over and give you a ticket. And once he pulls you over, remember "he is always right".
You can tweak your lights all you want, but just be aware that drawing attention to your vehicle from the public, will also include drawing the attention of law enforcement. I have met cops that are nice and cops that seem hellbent on ruining your day. You don't know which kind they are until they walk up to your window.
I live in saudi arabia if anyone cares
U guys are probably right i will cancel this idea
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
