TSB? No way as this is a safety issue. Tail lights are required and if there is a possibility that they fail due to crappy piss poor overseas inferior products due to cost savings attempts, then it will be a recall. If I had a light out because of this and the police pulled me over and gave me a ticket, I would force GM to pay for that ticket (if I had to keep driving waiting for a part).
GM has no shame in penalizing their vendors if they give them crap products for safety issues, even if it is their own fault for sourcing and not properly testing the products. Hopefully it becomes a lesson learned for them through this as every recall is a blemish and costs them potential buyers.
My '14 has already had 3 recalls and one item fixed for a TSB (which is now a recall). Pretty sad.
Yup just like I said a TSB. I can't tell you how many brake lights I see out on a regular basis. No recalls for them on a "required" item. There are 3 brake lights that are on the back of these trucks I bet it only needs 1 to be in working order to trigger a major safety problem it would have to be that none of them are working. Like it or not. GM would only fix your problem and tell you to pound sand on the traffic ticket.
Oh yeah I owned a 14 so I know what you mean by recalls.
Edited by Blue Sierra Owner
Did you take your truck to your dealership with a taillight not working and they sent you away?
Yes sir. State of Kentucky only requires 2 tail lights so even if I fought for a rental they would laugh at me and say I still have 3.
You shouldn't be so quick to offer up "opinions" as it provides false info to those that read these. Since you are from Atlanta, this is what is required for Georgia (pay close attention to point b);
O.C.G.A. § 40-8-26
GEORGIA CODE
Copyright 2016 by The State of Georgia
All rights reserved.
*** Current Through the 2016 Regular Session ***
TITLE 40. MOTOR VEHICLES AND TRAFFIC
CHAPTER 8. EQUIPMENT AND INSPECTION OF MOTOR VEHICLES
ARTICLE 1. EQUIPMENT GENERALLY
PART 2. LIGHTING EQUIPMENT
O.C.G.A. § 40-8-26 (2016)
§ 40-8-26. Standards for brake lights and signal devices
(a) Any motor vehicle may be equipped and when required under this article shall be equipped with the following signal lights or devices:
(1) A brake light on the rear which shall emit a red light and which shall be actuated upon application of the service (foot) brake and which may but need not be incorporated with a taillight; and
(2) A light or lights or mechanical signal device capable of clearly indicating any intention to turn either to the right or to the left and which shall be visible from both the front and the rear.
(b) Every brake light shall be plainly visible and understandable from a distance of 300 feet to the rear both during normal sunlight and at nighttime, and every signal light or lights indicating intention to turn shall be visible and understandable during daytime and nighttime from a distance of 300 feet from both the front and the rear. When a vehicle is equipped with a brake light or other signal lights, such light or lights shall at all times be maintained in good working condition. No brake light or signal light shall project a glaring or dazzling light.
© All mechanical signal devices shall be self-illuminated when in use at the times mentioned in Code Section 40-8-20.
(d) All lenses on brake lights and signal devices shall be maintained in good repair and shall meet manufacturers' specifications.
HISTORY: Ga. L. 1953, Nov.-Dec. Sess., p. 556, § 112; Code 1933, § 68E-207, enacted by Ga. L. 1982, p. 165, § 4; Code 1981, § 40-8-26, enacted by Ga. L. 1982, p. 165, § 10.
Well, if that is the law, then what obligation do you think the OEM has?
Yup I fully understand the laws governing lights in Ga. I was a truck mechanic and driver for several years. There are several laws broken every day so I guess we are all law breakers? Do you always stay under the posted speed limit? I bet not. As for what I said. GM, Ford, Dodge, or any OEM you pick is going to repair the problem of an out of service break light if under warranty or you will have to pay to have it fixed if the warranty is expired. I also bet that their definition of an out of service break light also means any one of the ones on the rear are working is good until the problem is fixed. By the way Ga will only give you a "must be fixed" ticket and all you have to do is present that the issue is fixed and it will be taken care of.
There has to be moisture to rust. I used dielectric grease on my old Ram tail light connections. Haven't done it on my chevy but it is amazing stuff
That is the stuff we used on the trucks I used to work on. It works great!
This isn't a discussion on how we drive or choose to break laws. This is a safety item on a vehicle that GM has to address. Simple as that.
Ok you win have a nice day. Edited by Blue Sierra Owner
  • 2 years later...
GM definitely has a problem with their rear tail light bulb main sockets corroding.  I have a 2015 gmc sierra 2500 hd and i had issues with the right side turn signal main socket corroding and that was 3 years and 6 months after i bought it and of course the warranty had expired with 25,000 miles on it and dealership basically told me we can replace it for you cost of parts and labor, so I got a new left side wiring and connectors and did it myself part was around 75 dollars and took me about an hour to replace.  Now i am having the same issue a year and a half latter with the left side so another wiring harness and and another 70 bucks gone.  GM doesn't care about their product and i even went as far as filing a complaint with NHTSA, said they would look into it but never heard anything back.
Edited by Darrell Oinas
Right rear went first then left rear, i stated it backwards
I purchased my GMC Sierra in June of 215, by summer of 2017 the first light bulb went out. I should have looked in to it then but i did not. When several other bulbs went out in December of 2017 I took it to the dealer.  It was only 30 months old, but I had around 39,000 miles. They said it was not covered by warranty. I said this is really not millage related, that the corrosion for the Honduras made wiring harness was due to poor quality not millage.
They stilled did not cover it. I am always surprised how much money they spend marking to me, attempting to get me to buy a new truck. I purchase a new rear harness, bulbs and sockets. Replaced everything.  Well it is 5 years latter and now I am looking for a new truck. I have had 4 GMC trucks, I purchase a new truck every 5 to 7 years.  Time to give Ford a try.
Edited by TheFlagInspector
My 2017Silverado  had the same thing.  Upper passenger side had corrosion in it and didn't work.  35,500 miles and fixed under warranty.  Bill said they replaced harness.
Jim
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
