DAMNIT!
pacodiablo
Yesterday I cleaned out the carb on the tractor and I thought I was doing it some good because all of this swamp water looking stuff came out (varnishing?), but, I put the d**n float in wrong, AND I CAN'T FIGURE OUT HOW TO MAKE IT GO IN RIGHT!!! This pisses me off to no end. And to add to my troubles, I broke one of the screws that holds the carb in place! It is not just any 'ol screw either...I highly doubt I will find this one in home depot.
The float valve is sometimes attached to the float with a small bent wire. All you have to do is hold the float in the "up" position and the valve should be forced into the closed position onto the seat. When the float drops as fuel is used, the valve comes off the seat and allows fuel to flow. Just be sure the valve is in the correct position on the float.
Do you have any pics that might help us, help you figure it out? As for the screw there is a place here in Goldsboro that seems to have everything. what make and model is it off of? Maybe I can help you find one.
Really it is a matter of which side is up as far as the float and valve are concerned. I tried to show it in the pic with as much detail as possible.
If you can get me any numbers off the carb and engine I will run by Hoods and see what they have. :thumbs:
I woulden't do that yet, I am broke and would have to pay you back at a much later date...lol. Is Hoods a store? I may be able to make it down there.
The carb is a Walbro, all it says on it is "5-4993," "LMT," and "2930."
The engine is a Briggs 286707.
Yea it is Hood Equipment. This guy has so much stuff packed everywhere I'm surprised he is allowed to be open for buisness. I mean you could go through all the stuff for years and probably find parts for anything. I guess he has a system that works for him but if you ask me it just looks like he just piled it all up all over the place and where ever there is an empty space. :cheers: He knows his stuff. Helped me get parts for an old IDE weed wacker just by going by the part I had in hand no need for the numbers, (although they help a ton)
I can cruise by and see what he has. If I can get it no sweat. It can't cost that much and you can pay when you get the funds. I know how life can be and if I can help then great. :thumbs:
The pointy end of the valve goes down into the hole where the fuel comes in. The tabs on the float will fit around the other end of the valve. There should be a shaft that the rear (valve side) of the float pivots on. If I remember correctly, it is easier to assemble the float and valve and then set it in place and then slide in the pivot shaft. It can only go in one way. The carb cover holds it in place.
The float and pivot pin attaches to the float bowl and the tabs on the float fit around the valve end with the raised rim. The pointed end of the valve goes up into the carb body you have pictured into the hole the fuel line feeds. The bolt that is broken looks like the bolt that would go up through the center of the float bowl into the carb body. If you use a non stock bolt be very very careful not to overtighten it. The stock bolt is shouldered so that you can't squash the bowl.
I decided to buy a shop manual today (maybe I should have done that before, LOL).
A "Small engine repair manual" should do fine. It would cover a lot more things than something that is brand specific.
I found a small engine manual, but I want something that covers the whole tractor so I bought a 624 page single cylinder tractor manual.
Paco,
If your on line I need the type number off the Briggs so that Hood can search the micro phish. (sp). the 286707 is great but now they need the Type # because they are saying that Walbro makes the carb for Briggs.
Also where exactly does it go? They are telling me it goes in the side. The bowl mount is part of the carb itself.
Price for entire carb is $112 price goes up 1 July. :) Ouch!!! I need the type number and code number off Briggs engine. OK?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
