i had this problem a few years back after my first filter change. when you go to pull the old/used filter, there will be leaves sitting on top that will fall into the blower fan if you don't slip a sheet of cardboard or plastic underneath the filter before you pull it.
i used a telescoping mirror to find where the leaf was. and then i stuffed my hand in there and fished it out with my fingers. i could barely get it.
All you have to do is take out like 4 screws holding the fan in place in the passenger footwell. I had to do this last time I replaced it. One leaf was causing the noise. I only replaced 3 of the screws because one was at a weird angle and stripped the head of it.
Thank you. I was hoping it would be fairly simple, and I was going to look after work today.
Perfect. I will try that first, then pull the 4 screws if that fails.
On one of the threads, someone had the bright idea to cut a sheet of thin plastic the size of the filter and then slid this under the filter before they removed it. All of the crap on top of the filter then fell onto the plastic instead of down into the fan.
I'm going to try this when it comes time to change my filter again.
Pretty sure that was me with suggestion, tho i wasn't the first to try it out. Had to wait 20,000 miles or so before i had to replace that filter again.
We had these thin plastic cutting board sheets we used in the kitchen. i stole one and cut it to the right width to slip under the filter before i pull it. i've done this job now like 3 more times since the 1st change, and every time there are leaves laying on top of the dirty filters.
After I read your suggestion, I was able to talk my wife out of one of her old cutting sheets....I'm sure she just used that as a reason to get a new one.
I finally got the tiny little leaf out of the frickin fan, but man, what a pain. Looking through the opening for the filter, using a small flashlight and a little retractable claw tool, I got it out. I will definitely steel one of SO's thin cutting boards prior to changing it the nest time. Good idea.
Why use a plastic sheet? Just use one side of the carton the filter comes in ??
Steve, mine didn't come in a carton....both times shipped in a sealed plastic bag with AC Delco part stickers on them.
Ive been using the Fram fresh breeze with charcoal from walmart...paid $14. The carton is the size of the filter i just cut out one end and voila....debris shield
Edited by Silverado Steve
You can cut up a box from your case of Budweiser or your flavor of choice and that too doubles as a debris stopper.
  • 2 years later...
I was losing my mind as I was having the exact same problem as the OP!  going to go leaf hunting tonight after work!  The sound was driving me nuts
You could always use a compressor and blow it out if you cant reach the leave. What happens if you run the fan on high wit it open it might discard the leaf that way .
  • 2 years later...
Found debris including a dry leaf in fan blades. Must have dropped off old filter when removing. Was able to get it out with fingers and then I used vacuum with crevice tool to suck out rest. Fan blades are directly under filter. In my case, an easy fix.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,671 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
