Filling with Gas
I had this issue with my 14 sierra. I mentioned it when in for a recall and they replaced the vent valve in the filler neck and I haven't had an issue since. Service writer mentioned that they have had to replace many of these.
  • Replies 49
Every gas station I have used here in Missouri still has them. Didn't know they were doing away with them. Good to know it may be coming.
I think this is what I'm going to do when I go in for service next. I also only fill up my tank when it gets super low so maybe I will try filling up sooner and pulling the nozzle out a little bit
The pump handles work on a venturi system.
try pulling the handle out a little bit. I test gas systems all day and see it all the time
Also for states with federal stage 2 vapor recovery, pump slow to save money as some product is inadvertently pulled back into the system. This system is slowly being decommissioned.
No problem with this truck. I did have a car with that issue but if I backed the fill nozzle out of the fill tube about half way it would fill fine.
No problems with mine, and I put the nozzle all the way in and lock it on high. Just filled up tonight, in fact. 21.162 gallons. It clicks off, then i usually put in more until it clicks again. What I noticed with this vehicle is that it only continues to fill for a half second before shutting off again. In my old car it would go another 15 seconds before clicking off again.
Most stations have eliminated the lock on the nozzle anyway.
Some stations in my area do not have the nozzle lock. I just begin filling and then shove the gas cap under the nozzle trigger and let it fill up.
As for having issues taking gas, neither truck causes the pump to lick off unless it happens to be one of those SUPER fast pumps that puts out (or attempts to put out) 10 gallons a minute.
Hey everyone,
Am I the only one who thinks it's a pain to fill these trucks up or is it just my truck? Every time I go to the pump, regardless of which gas station, I can't set the pump to automatically fill because it keeps popping for the first couple minutes?
Thoughts?
I find it very easy, I pull up, roll my window down, tell the freezing cold gentleman to fill it up, a few minutes later it's done.
I've had this issue too. Dealer didn't seam to know if there was a fix. I'll have to ask them about he vent valve next time.
I have yet to see a station around me w/o the nozzle lock, unless you come across one that's just broken. Also no issues w/ filling my truck.
In Ontario the Shell stations are the only ones that I have seen that still have the nozzle lock. It's illegal to put the gas cap in the nozzle as well. Almost seems like they want you to get frostbite or something. Isn't gasoline and its vapors a carcinogen? Maybe a lawsuit needs to happen to bring back the nozzle lock. ?
I had this issue maybe the first couple tanks until I figured out how to "correctly" put the nozzle in. We don't have the auto fill on the pumps but I wedge the gas cap into the gas pump handle and auto fill that way. Haven't had this issue now since like tank #3.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
