What do I need and Kit Suggestions
First off, I apologize for creating a new thread, but I keep looking through all of the HID posts and get confused. I have a 2014 GMC Sierra and would like to upgrade my headlights to hid, but can't figure out all that I need.
So here it goes.
1. What pieces do I need besides the HID kit?
2. Does anyone use a kit from amazon?
Check out theretrofitsource.com
They have complete kits for the 14+ trucks. Morimoto is a great quality HID kit with a 5year warranty also.
2nd vote for the Retrofit Source Morimoto GMC spec kit. Cost is higher than others but you get what you pay for. I have the 35W 4300K kit and no issues in over 2+ years with them installed.
Would I go with the low beams or high beams? https://www.theretrofitsource.com/all-products.html/?car=gmc_sierra%20%20_2014
Anything I need to look out for?
I upgraded my 14' Sierra to HID's almost a year ago and absolutely love them. They are brighter any other car around. I went with a place called Enlight Automotive. Very high quality seeming products and very nice guy to deal with. I purchased my HID's and also foglight LED's from this guy and they are amazing and VERY bright! I also upgraded to the 55W ballast. Full kit and he even has a great install video.
https://www.enlightauto.com/collections/enlight-your-2014-2015-2016-gmc-sierra-hid-kits-led-lights/products/2014-2015-2016-gmc-sierra-alpha-series-xenon-hid-headlight-kit
+ 1 on Lgetz' recommendation. I have the '14 SLT and this was the direction I went 18 months ago. Best thing I've done with the truck. The GMC doesn't have a separate high beam; it uses a shutter in the housing to block some light when in low beam. The Morimoto kit works on SLE and SLT trucks.
For a few months, I guess. I went with TRS because I trusted them and they're easy to reach out to and ask questions of. Their kit is easy. The most difficult process is trimming the rear cap of the headlight housing for the new wires.
I think you guys talked me into getting a quality set, but I have the SLE package that does not have the LED DRLs. What do you suggest for lights with those? Wouldn't they be on constantly with the DRLs?
I second this. I originally went with DDM tuning cause it was cheaper. Lasted me about a year before I had issues. The wiring and components on the Morimoto kits from TRS are top notch, everything is labeled as well which makes install simple. Wayyyyy better than cheap kits. And great customer service from TRS.
Looking for some help on this one, my headlights are the DRLs, what is my best option for HIDs with that? I really don't want HIDs as my DRLs. Has anyone replaced the whole headlight and added HIDs? Would you suggest doing that?
Poke around in the "What have you done to your K2 today" thread. There are a lot of good ideas. It'll take some time, but start at the beginning and work your way through. The same can be said of the HID Headlight thread(s). The "What have you done..." is now part of my daily reading!
I did a quick search for "SLE" in the HID thread and found these:
Potential polarity of capacitor in kit causing flicker (just reverse the 2 wires on the capacitor):
http://www.gm-trucks.com/forums/topic/152762-hid-headlight-bulbs-hid-projector-retrofit/?p=1705416
This guy's been running them on his SLE for 2.5 years without issue:
http://www.gm-trucks.com/forums/topic/152762-hid-headlight-bulbs-hid-projector-retrofit/?p=1887630
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
