Bed lights.
I was installing my tonneau cover and after 5 months of owning the truck I noticed the lights in the bed. Only problem is how do I turn them on? I have no idea where I put the manual
try this,
Cargo Box Lamp
With the vehicle in Park, press to turn the cargo lamp and under-rail pickup box lights on or off. The button indicator will illuminate when the lights are on.
I did Google shortly after. This thread cab be deleted
i noticed mine after installing the cover. went to use the light and saw them on. excellent design option. good for when the cover is closed too
