On 4/11/2018 at 4:58 PM, JohnnyCruz said:
Almost done; I received this picture today from the shop. I'll take more pictures once I pick it up.
did you have to change the lights harness or the same one is good for the change of lights .??    can i get the list of parts # so I could try to do mines that way, looks awesome by the way.....
  • 4 months later...
On 4/10/2019 at 11:19 PM, Mileguru said:
Any significant improvement to the performance?
I already had a cold air intake and the. Borla exhaust when i installed all this , not sure if there were any real gains but i am very happy with it, i know im late with my response
On 6/24/2019 at 7:14 PM, SirenRed16 said:
This guy did it also and said it took a lot of work to make it fit24448c6bc0c53e235de7b9d8fd4af116.jpgba5d67ce975926b456e11eec2df85f51.jpg
anymore specific details on this hood swap?
No but but I'm pretty sure I recall him saying it needed a lot of custom fab work to make it fit properly.. it's not like the GMC, they seem to be a bit easier
10 hours ago, Sergio Rodriguez said:
So you bought all parts online from gmdirect? And also what color did  the hood came in?
I bought mine online and picked it up local. If you can pick it up instead of ship it, you will saves hundreds of dollars. If you buy all the parts at once (hood, insulation, tuning, etc), shipping was over $250. I ended up buying them and picking them up. I bought everything from Quirkparts.com, they had a local warehouse to me.
The hood ships primed black.
On 4/21/2020 at 9:26 AM, Sergio Rodriguez said:
And you order everything from a 2017 2500 HD? I have a 2014 Gmc 1500 And I’m trying to swap the hood
there is a different grill on the 2500HD. I already have an 2500HD, so I only needed the hood, insulator, the trim and the plastic piping to the air box. Plus the various nuts/bolts. You will need the HD hinges as well.
There is a post on putting the HD hood on the 1500 and includes the part numbers. Here is the link:
Do any on you know the parts list for the internal components in the hood? (2017 Silverado 2500hd)  I already have the hood and intake vent but Need to know the quanity for all the other parts on the inside so I can order.
by the way....this is going on a 2016 Silverado 2500HD. Thanks!
Do you know what the weight difference is? Notice any performance benefit because of the colder airflow or is it purely aesthetic with your truck.
    Artemis
    Artemis
  • Who's Online   4 Members, 0 Anonymous, 1,234 Guests (See full list)
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
