I have icon 2.5 and cognito UCA and 2inch block sitting in a box that arrived yesterday. I plan on setting suspension at at least 2.5" but concerned about CV angles at that high of a lift. I found a diff drop kit on ebay and thinking of using it but it requires some cutting/grinding of cooling fins on the diff case. That has me real nervous so might not do it depending people's opinions of CV angles raised 2.5". Anyone have any issues with cv angles at this hight? Should I just grind and it really not a big deal or am I potentially damaging or weakening the case?
Sent from my SM-G920V using Tapatalk
Skip the diff drop. If your boot fins are rubbing you can remove the factory outer clamp extend it until no rubbing and install a new crimp clamp or a marine hose clamp.
Sent from my SM-G930V using Tapatalk
No way I would do it, 2.5" leveling kit is too much on the CV angles and as far as stretching the cv boots that will really kill the boots as the bottom side of the boot will be stretched too much and they will rip quickly. As far as cutting the cooling fins off it depends on how much you have to remove
Not sure if you'll have to cut the fins off the front diff. Im thinking some diff drops are different than others. I say that because, I saw the Rough Country 3.5 inch lift comes with a diff drop and it says you need to cut the fins and notch the cross member. But the 3.5 superlift kit comes with a diff drop and they specifically advertise NO Cutting what so ever. So I would contact superlift and ask them about there diff drop.
But either way I would do the diff drop. Just my opinion.
Because it comes with a new crossmember the differential doesn't need to be trimmed. But your cutting the factory crossmember
"High clearance, one-piece crossmembers, and all other load bearing bracketry, is laser cut from .25" thick plate steel. No differential trimming required, plus the factory front drive shaft is retained"
Edited by Bushleaguechew
I'm talking about the 3.5 in kit, just like the 3.5 inch RC kit, it's just big top spacers​ for lift, new UAC'S for proper ball joint angles, and the diff drop for proper CV axle angles. In this superlift 3.5 kit they say there is no cutting required. For the diff drop.
This kit has no new crossmember. But again requires no cutting.
http://www.superlift.com/3-5-inch-upper-control-arm-uca-kit-for-the-2014-2015-chevygmc-1500-2wd-pickups-with-factory-aluminum-control-arms
Do you have a 2 wh Dr? That one is for a 2 wh Dr.
Sent from my Nexus 6P using Tapatalk
It's a snowball effect. I have a 3 inch right now and really wanting more lol. Really want 6 inches. That's when prices jump way up
That's what she said!
That's what I'm seeing to and believe the consensus is to drop even at 2.5 lift. Being that I don't have much wrenching experience on trucks , if I grind can I go back if I want to return to stock if I change my mind. Also open to here from others about angles at 2.5 lift as it seems lots have 2.5 levels and don't do anything for diff drop
You can remove the spacers and put your differential back to its stock height but you can't undo the grinding away of metal
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
