Lights behind 4x4 selector
Just randomly noticed that where my knob says 4L it has a N for neutral but at night it seems like either the light behind the N is either out or there just isn't a light behind it at all. Anyone else with a 4x4 know if there is a light or not just curious?
There is a red light. You have to put the transfer case in neutral for it to light up. It is not illuminated otherwise.
What you are likely seeing is bleed over of the white LED for the 4L through the transparent "N" not a defect or noticeable during the day.
One time when I started my truck, I saw that "N" light up red just for about 2-3 seconds then it went out.
Is that normal, what does that mean?
I do have a Range AFM disabler plugged in, wondering if that was screwing with it?
does this sound like what it is doing?
Use the transfer case knob next to
the steering wheel to shift into and
out of four-wheel drive.
An indicator light displays which
setting the transfer case is in.
N (Neutral) is indicated on the knob.
If the light displays momentarily
when the ignition is in ON/RUN, but
does not stay on, the knob may
have been turned while the vehicle
was off. To see the indicator, turn
the knob to another position so that
it matches the actual transfer case
setting. If no lights display, take the
vehicle to your dealer for service.
I don't believe the knob was turned when the vehicle was off, but maybe it got bumped
Don't know,it never happened again so I don't know.
But thank you for the info
you are very welcome. I did notice that my switch did the same when I went to lunch, neutral light turns red for about 3 seconds when truck is started, going to guess it is normal. never have had an issues with the 4WD system.
Generally, your truck should illuminate all indicator lights upon startup. ABS, traction control, charging problem... probably including the neutral light on the switch. The reason for this is so you can check and see if any are burnt out, or more likely now that they're LEDs, disabled by a seller. If you hop in a truck, turn the key to on and don't see the check engine light, or other key indicators turn on for a few seconds, you're going to want to scan that thing before you buy it.
