Leather - not plastic
Spurshot
I thought a leather thread might be interesting.
These two holsters and magazine carriers are from Davis Leather Co. The model is their Gunsite Omega. You can see the Gunsite shooting academy logo stamped on them. The hangers are interchangeable to go from belt ride to drop. Simple and elegant design that works. http://davisleathercompany.com/
The belts are from Comp-Tac and have a kydex reinforcement laminated in the middle to stiffen the belt. http://www.comp-tac.com/
Show us your leather.
I can't, mine's concealed. ;)
I'm currently using an old faithful holster for my daily carry.
I have a Simply Rugged pancake for my Taurus 44c, I carry it ISB with loops and as a chesty puller when hunting...I also have one of their 1.25" and one of their 1.5" belts, plenty stiff to carry ISB.
I highly recommend their products, very nice fit and finish.
Sent from my SM-T350 using Tapatalk
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
