2500 HD 6.0 input
I just did the same swap, but went from GMC SLT 2wd to CHevy LT 4wd... only have had 4 days
is that a pre-owned? can't imagine dealer installing fender flares. awesome truck. enjoy it.
Nope, new. That was part of the $9,995 accessories the had on it. Haha
Thanks everyone. I did a roundtrip to Anchorage today, showing 14.8 mph on the dash which isn't far off what I was doing with the 5.3 in cold weather (28 here today and got about 8" in Anchorage).
Things I noticed:
-A lot of drivetrain whine in 4wd
-very touchy steering (darts around in the lane)
- way stiffer ride but expected with the Z71 package.
I used to be a die hard Ford guy (had an 02 F250 with the 7.3 and numerous other Ford products). But I've been very pleased with the 1500 and very happy with the 2500 so far. It was a deal that was hard to pass up and glad I did it.
The 4wd noise is normal. The gas trucks use the diesel spec chain which is a stronger and double wide chain and produces more driveline noise. Steering, read some of the threads on the variable assist steering here.
Very nice truck! You can check out my build thread if you're looking for any ideas, haha!
Well, I went ahead and pulled the trigger. Just a preliminary shot, but here she is. With all the accessories and packages, sticker was 68k. I got it for 53k and some change.
Sweet! You'll notice a major improvement over your 1500 when towing or hauling!
AK Gonzo where did you do your French Commando school? I did mine in Berlin!
Larousse, France, 1987
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
