Location on passenger side to ground a wire?
I have been trying to find a bolt on the passenger side to ground a wire for an accessory on my passenger side. I can't seem to find one. Anyone have a pic of a good spot to use?
Pull off the fuse box cover. Look at the corner of the firewall and A pillar. Should be a few right there.
So today I learn that there is a fuse box on each side of the dash.
Goes to show it's been a while since my last truck 89 Ram. I now wonder if that little Focus I was putting around in had the same thing.
I will check this out after my daddy daughter dinner date. Thanks for the info.
It wasn't my ground wire. My wire tap didn't set properly. All is well in the world now.
nice! what did you use?
:). X51L and X51R. In case you need pinout for connectors. Like, I didn't know there were two as well until I started poking around the Upfitter manual.
For those looking for a cheap and dirty accessory ground, there are small 5/16" ish holes in the frame for the center seat (if you don't have a console). Sand the paint away and ram a bolt through an eyelet
Found some strip LED lights at my local dirt Cheap. Basically what you can get from auto zone. Paid $7 for the strip $3 for a pack of quick connectors. I even stepped it up and spent another $4 on some good wire. Lol
I'm not 100% understanding this. Is there a thread or something you can point me at that will explain.
The Upfitter manual I reference is a manual used for 3rd party outfitters. Check out gmupfitter.com. This is where we obtain the electrical schematics for our trucks. For 2016, it's a 1688 Page PDF [emoji23], goes into great detail. The Fuse panels in our trucks are labeled X51L (Driver's Side), and X51R (Passenger Side). If you search for these labels on the Upfitter manual, it'll give you specific circuit detail and pinout locations.
did you connect it to a fuse? I suppose that's one way to go. I have a few led strips left from my cabinet project.. I think could use those.
UPDATE: I found the thread so i'll be doing this soon!
Yea I tapped into the A pillar. I started working on the back tonight. Will finish tomorrow.
I pulled off the little panel on the bottom rear of my center console and grounded from the crossbar behind it for my subwoofer upgrade. Works great.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
I'll keep that in mind. Plan on eventually adding a single 10 later.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
