Tire opinions
Trying to decide between 33x12.5x20 toyo mt or the new ridge grappler. I have a 2017 1500. Toyo is tried and true but I like the idea of the hybrid. Don't know anyone running them locally so I'm asking anyone on here their thoughts??
I just put 33x12.5x20 Nitto Ridge Grapplers on my 2014 Silverado and I love them. They look really good and are pretty quiet. I have an RC level with 2" blocks in the rear. They rub the sway bar at full turn, but that is expected in that particular size.
Member Toddboy23 has a GMC with Toyo's and was the inspiration for my set up.
http://www.gm-trucks.com/forums/topic/160069-my-2014-sierra-at-rc-level-and-33x1250r20-toyo-mt/?p=1438080
Salt consider the Toyo RT as well. Have them on my truck and they look and drive great. Not too noisy on highway as well.
I read on this forum for over a month trying to decide on tires. I finally went with Nitto Ridge Grappler in 295/55/20 on stock rims. I have gotten lucky enough to have them in snow and mud on a 500 mile trip i took. They handled perfectly and ride really quiet for such an aggressive tire. I love the way they look on my truck. They barely rub on stock 20's at full lock. I will post some pics this week.
I like the look of those. But I know some people running those that wished they would have just gotten the m/t.
Well I live in Georgia so no snow here lol but as far as mud goes we have plenty. I'm glad to hear they handled mud. Thanks for the input!
Nitto's website has some good info on their tires. For some reason the 33x12.5x20 has more tread depth than the 295/55/20 but is the same height. The 295's are also 7 lbs lighter.
http://www.nittotire.com/light-truck-tires/ridge-grappler-light-truck-tire/
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
