changing the thermostat
chris918
iv always wondered what advantages are of changing the thermostat to lower temp from 210 degrees stock to 180-190 besides the obvious of the truck running a little colder any info would be much appreciated thanks
Leave it alone. Zero benefit for a daily driver. Modern vehicles are engineered and optimized to run at higher temps.
That was worth a good laugh.
Wonder how much more fuel you're using because the engine 'puter isn't registering proper computed engine temperature???!! Just saying.
i didn't do it iv just heard of people changing them didn't know what it would do besides lower temp
If these trucks are designed to run hot, they're designed to run hot. Only application I can see usefulness in cooler temps is boost.
This went hand in hand with computer reprogramming in the 90s. The thought was the lower temperature thermostat would allow a denser fuel to be delivered to the TB. You needed to reprogram the computer for it to know that you changed the thermostat.
I'm not sure it did anything...it was a common mod in the Trans Am and Camero crowd.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 298 Guests (See full list)
