Does anyone know a way to drop the volume of in-cab door chime on a 2015 Sierra? I don't want to simply unplug / fully disable, but man is that thing LOUD. Haven't tried to physically get to it yet, but the thought of wrapping in foam has crossed my mind as a possible solution.
If I'm ever talking on Bluetooth phone when forgetting seat belt, it nearly deafens whoever is on the other end of the call. Thanks!
~Vol
The touch screen lets your lower it......... I always set to not honk at me when locking - and lower the volumn on chimes etc..........
Edited by Krusty
Any idea which menu? I'm pretty familiar with the electronics and I don't recall ever seeing that option. Maybe I read right over it, or else it's an option in your 2017 Silverado NOT in my 2015 Sierra.
I remember seeing a chime volume in the settings somewhere. Mine is all the way off, but I still hear the chime, I don't think it adjusts the door open chime. Im not really sure what it adjusted.
Edited by SkiDooNick700
See "Vehicle Personalization" in your manual......... Page 5-50 in the 2015 manual... page 168 in the 2016 manual (more like page 161 in 2017 manual)............... I also have the radio start-up set low.......... Enough noise at work and everyday life !
:freak:
Edited by Krusty
You can also get rid of the annoying seat rattler and have it do just an audible alert.
At work right now, but I'll see if I can find it later this afternoon. Thanks for the tips. I'm gonna feel like a moron if it's in the settings and I just never saw it. Doh!
~Vol
I had the same concern with my '15. The chime control available on the vehicle DIC menu didn't fix the issue. My dealer was able to dial it down to a tolerable level.
I did find the setting, but it was already turned all the way down. I played with adjusting it both up & down but like SkiDoo, I couldn't tell that it was doing anything at all. There's another setting in the same area for auto mirror that I *think* is supposed to fold in the mirrors when parking. From what I can tell, toggling that setting on or off has no effect on anything either. Will have to read the TSB link when I have more time. Maybe there's a known firmware glitch where some of the electronic settings are being completely ignored?
I took my 2014 in last year because of the extremely loud door chime and the dealership did the TSB. It helped but didn't eliminate the problem. The first chime or two are still very loud but the last few get quieter the longer I let it chime. Mine was originally so loud it hurt my ears and that is saying a lot because I can't hear worth a damn from my dumb days in my youth when shooting guns and running equipment without proper hearing protection.
There have been many complaints about this (search the forums for other threads). Most of us have the volume turned all the down in the settings and had the TSB done and it's still too loud. I just ended up buying one of these:
http://www.seatbeltextenderpros.com/gmc-sierra-seat-belt-extender/
Get the 3" rigid in the color to match your interior. Plug it in and leave it there and the seatbelt chime is gone!
Edited by sk
Until I had mine turned down by the dealer, I tried to remember to snap my seatbelt prior to stating the truck. I don't like to defeat any warning signals and was glad my dealer was able to repair this issue.
Oddly enough, I already have a couple of those from the exact same vendor! Mine are currently in the back. My kids are still in booster seats, and the extenders make it much easier for them to get buckled. As luck would have it, my daughter just crossed the age where she no longer needs the booster, so I may be able to relocate the extender. Great idea. Hadn't even thought about that.
Has anyone fiddled with the chime module itself (or is it even reachable without major dashboard teardown)? I'm still thinking about a good foam wrap. Also wondered if a resistor could be spliced into one of the feed lines. The mechanical engineer in me refuses to give up. :)
Did you ask your local gm service department if they can turn down your seatbelt chime?
    ncleg
    ncleg
  • Who's Online   0 Members, 1 Anonymous, 1,281 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
