I've hunted all over my truck to see where this goes. Son found it on the floor while using my truck one day. It has a number of 15298138 stamped om it. Did a search of the number and came up empty. The truck is a 2010 HD2500 with a center console if that matters. I put it this forum as I though it would get more hits. If needed to be more to the HD forum so be it.
Thanks in advance
Did you check under the seats? It is probably a cover for some controls under there.
Almost looks like the trim piece that covers the two bolts on the door panel by the door grab handle!
Edited by demech23
yeah it does
That was my guess also.
Sent from my E6810 using Tapatalk
Just went out and looked all over again. It's not the plastic trim piece behind the door grab handles. That part is curved, this one is flat. Thanks for the help so far.
I had a piece just like that when I purchased my 06 used. I found the proper place for it after searching for days was in the glovebox next to the owners manual.
Kinda looks like something associated with a glove box or console lid latch, or maybe an under-dash or end-dash cover (fuse panel cover?) of some sort.
  • 5 months later...
  • 3 years later...
