Puddle light wire?
I want to wire step bar led light to puddle wire. I don't actually have a puddle light on my mirrors but is that wire exist, if so which wire and will the puddle light turn on if interior dome light is switched on or only turn on when you unlock car?
  • Replies 59
Puddle Lamps only come on at night and when you unlock your doors (with key fob) or open your door. It turns off after a few seconds of closing your doors. It kind of operates like the dome but is independent. It will not come with the dome lamp switch.
Here is a pic of the circuit in the BCM. Far left grey connector. Bottom right corner of the connector (solid grey cable). Ignore the diode.
Tie it in with the cargo lamps and problem solved. The wires are right there so no need to go hunting them down
Do you know the exact place for the cargo lamp wires?
Do you have the bed lights? That's what I tied mine into, they come on with the cargo light. I can take a pic of each side when I get a chance today
Sent from my SM-N920V using Tapatalk
I'm assuming there are two grey solid wires, we are taking about the thicker solid grey wire of the two right? The smaller one seems to have grey and strip black of some sort. I was reading some of the other posts, and this wires seems to be the dome light is it not?
The solid (thicker) grey cable in Pin slot # 1 is the dome lamp circuit. The thinner grey wire with a light green stripe is the Puddle lamp. The Puddle lamp is Pin Slot # 8. Counting from right to left in the view above. If you want to the he Puddle lamp, you'll want the thinner grey wire with green stripe.
I plan on tapping the puddle light when I do my step lights. It makes the most sense. They will only come on when needed and no other system will turn them on.
  • 1 month later...
Did mine this morning, and the puddle lights will NOT turn off. 1 is a grey wire and 8 is a green wire, from what I can tell. I have more wires in my grey plug, than what you have shown here.
So the puddle Lamps stay on after the dome lamp turns off?
Yes.
Yes.
That is odd.. I'll look into this when I am back home. Can you PM me pics of the back side of the connector? Also let me know what year and trim your truck is.
I DO NOT UNDERSTAND IT!!!!!!!!!! :banghead:
I JUST DO NOT UNDERSTAND IT!!!!!!!!!! :banghead:
I AM TOTALLY STANDING BESIDE MYSELF (and my truck)!!! :banghead:
I reinstalled the diode........
AND
IT
WORKS
AS
ADVERTISED!!!!! :dunno:
I JUST DO NOT UNDERSTAND IT!!!!!!!!!! :devil::banghead:
The electrical system could have just had a brain fart. Seems common on these K2's. Mine has hiccups occasionally.
LOL. All good. As long as it works now... I can stop fishing for the red herring.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
