So I have a 15' denali with 6.2l. I have been noticing more and more when I look at it the front end really comes down
I want to do a 2.5 leveling kit but feel I may need to do more in the front to "level" it out.
Add a couple inches to the front end and that should be good, unless you just want to get a straight up lift kit. I added the bilstein struts up front to my 14 on the 1.85" lift setting and I constantly debate on adding a leaf to get some of the rake back because the front is so high.
2014 Silverado Z71
That's how trucks sit. A 2" level in the front will have it looking good. 2.5 and up start to put a lot of stress on the ball joints.
2.5' will over level you and you will be nose high. 2 inches should be perfect.
Edited by 15HDriver
are you saying only 2.5" front?
because i want to bring the whole truck up 2.5" plus level the front... so i am thinking of doing a 1.5" rear and 2.5" front. that way i bring the front up an inch to maybe make it closer to "level" to the rear
You should read some of the other threads on leveling and lifts on this forum. There is a lot of reading, but spending the time now can save you a lot of money. If you don't want to take the time then I highly recommend you take the advice offered of getting a 2" level. (1.5 is even better, imo). Your truck will appear level, maintain its current ride qualities and is not expensive. FYI, You will need an alignment following any modification to the suspension.
No. I am saying leave the rear stock and go 2 inches in the front. You wanted per your original post to level it out.
Quoting your original post:
Start to? A 2 inch does the same thing (add stress) just a little less than a 2.5. Anything over stock adds stress, the higher you go the more stress is added. A 1.5 adds stress, not as much as a 2 or 2.5 but it adds stress none the less...
Tyler
Tyler
Any level will add some stress, but it seems like the guys who did the 2.5 over the 2 kill ball joints much faster. You can read it in the leveling kit thread. I'm not saying it won't add extra stress, just not as much.
I just did 1.5" spacers under my front shocks yesterday (went with Motofab), very easy to do and I now only have a 1" rake instead of almost a 3" rake prior. Other than the nose riding higher I haven't really noticed any difference in the way the truck drives....Getting my alignment in a few day's.
Or we could load you up like a job site truck and you'll have 750Lbs in the bed constantly. Then hook up a trailer to it. That'll level you right on out.... Being seriously, the 4WD trucks have a better stance than the 2wd trucks. the 2 wheelers look nose low.
so then to add another factor to this boys... if i wanted to do a 2" overall lift while keeping the front level with the rear with 2" lift.. i am looking at a 4" front lift?
now with the denali i feel that maybe i may not want to adjust my shocks and such because then i will loose ride quality. i feel like i put myself in a crappy situation to really lift this vehicle while keeping the factory ride quality.
i want to be able to do 35' with 22's is my goal. i also want the truck to sit even
to do 35's i have seen guys going with the 2.5" lift and rubs a little. so will 35's fit with 1" rear lift?
No. 4 in the front and two out back. Not gonna happen. You could do 2in in the front and then a 2" body lift, but 35" you might as well do a Magnetic Ride Control compliant 6" lift and be done with it. I've seen the HD trucks fit 35" with a level. but the most on a leveled 1/2 ton I've seen fit good was a 33"
Edited by 15HDriver
Sigh. I really wanted to stay away from big lift. But go big or go home I guess
Could you leave the front alone - and shackle the back to level it and not lose ride quality on mag ride?
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
