6 minutes ago, RACERX7775 said:
What about adding another ground sensor for batt2 and wire that one into the factory sensor... they only cost like $25.
Im not sure of that would work. No clue if the truck could regulate 2    might as well give it a try.
Personally i would have wired it differantly and upgraded the ground and alt wire but thats just me
Usually, that would be the first thing i usually would do. But when i did the stereo on this truck, for some reason, since i did the charge cable to the second battery, i didnt wanna touch anything that was attached to the factory battery. I dont know why.... but that was just my thought...
This discussion has way more posts than i ever thought. The thing i noticed about some threads on here is, like this one, we can have thoughts and posts, right or wrong, and none of us has been rude, disrespectful, and nasty(no pun intended). This just shows that most who are on here really are nice people who want to help others.
Wow, i feel like my fem side just came out. LOL... Now Im gonna finish my beer...
Hi guys.. hope you don't mind me asking a question related to the dual battery... I'm running a factory isolator which needs a 12v and a 12v switched. My truck being a 2018 there don't seem to be alot of information regarding this... is there a switched 12v in the under hood fuse box ?
Sure there is. What FACTORY isolator do you have? Didnt even know there was one. Your truck come with single or dual batts? I wanted to go completely factory when i did my setup, but it was more than i wanted.
GM P/N 12135194). GM calls this a "secondary auxiliary relay".  I've got a single battery but I'm upgrading.
There is but this begs the question.....why not just keep buying the stock PnP parts?
Lol. And the topic cycle starts again. Lol
Edited by RACERX7775
I was litterally just on the internet looking at 200amp isolators for $59.
Yes this stock part is cheaper but not rated as high not that that is needed. But the price on the wiring for gm is up there. Still 200 for the whole kit isn't bad.
I guess depending on how much power is needed, it might be a good way to go. With both of my JL Audio amps, my max power is only 130 amps. I just tend to go bigger than what is needed. With everything. Thats why all my cable is 2/0..
Everything I got was cheap , as in not directly from gm , but mouser and a few others. Making the cables myself (1/0).
Now what I'm looking for is 12v switched in the engine bay ??
I cant tell you exactly what wire to hook up to. But just get the owners manual and find a switched fuse that you can tap into.
I was hoping to use an open pin or circuit.  Is this possible... I want to make sure I don't mess up anything in the bcm.. the electronics seem pretty touchy.
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 871 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
