6 minutes ago, RACERX7775 said:
What about adding another ground sensor for batt2 and wire that one into the factory sensor... they only cost like $25.
Im not sure of that would work. No clue if the truck could regulate 2    might as well give it a try.
Personally i would have wired it differantly and upgraded the ground and alt wire but thats just me
Usually, that would be the first thing i usually would do. But when i did the stereo on this truck, for some reason, since i did the charge cable to the second battery, i didnt wanna touch anything that was attached to the factory battery. I dont know why.... but that was just my thought...
This discussion has way more posts than i ever thought. The thing i noticed about some threads on here is, like this one, we can have thoughts and posts, right or wrong, and none of us has been rude, disrespectful, and nasty(no pun intended). This just shows that most who are on here really are nice people who want to help others.
Wow, i feel like my fem side just came out. LOL... Now Im gonna finish my beer...
Hi guys.. hope you don't mind me asking a question related to the dual battery... I'm running a factory isolator which needs a 12v and a 12v switched. My truck being a 2018 there don't seem to be alot of information regarding this... is there a switched 12v in the under hood fuse box ?
Sure there is. What FACTORY isolator do you have? Didnt even know there was one. Your truck come with single or dual batts? I wanted to go completely factory when i did my setup, but it was more than i wanted.
GM P/N 12135194). GM calls this a "secondary auxiliary relay".  I've got a single battery but I'm upgrading.
There is but this begs the question.....why not just keep buying the stock PnP parts?
Lol. And the topic cycle starts again. Lol
Edited by RACERX7775
I was litterally just on the internet looking at 200amp isolators for $59.
Yes this stock part is cheaper but not rated as high not that that is needed. But the price on the wiring for gm is up there. Still 200 for the whole kit isn't bad.
Sent from my SM-N950U using Tapatalk
I guess depending on how much power is needed, it might be a good way to go. With both of my JL Audio amps, my max power is only 130 amps. I just tend to go bigger than what is needed. With everything. Thats why all my cable is 2/0..
Everything I got was cheap , as in not directly from gm , but mouser and a few others. Making the cables myself (1/0).
Now what I'm looking for is 12v switched in the engine bay ??
I cant tell you exactly what wire to hook up to. But just get the owners manual and find a switched fuse that you can tap into.
I was hoping to use an open pin or circuit.  Is this possible... I want to make sure I don't mess up anything in the bcm.. the electronics seem pretty touchy.
    B07
    B07
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
