  • 10 months later...
So, as the parts came in, they sat around for a while(ok, a good while) finally got around to installing my dual setup.
I picked up the Keyline Isolator 300amp(for future, friends trying to talk me into Overlanding.. haha) and AGM H6(Costco). The design for the battery terminal on the back of the isolator could use some redesign, or make it like their 140amp isolators.  If you buy their kit, you get the right terminals to fit from the looks of it. I bought some copper tubing and made my own lugs to fit correctly on the back terminals.. 😮‍💨
I used some red wire-loom for positive cables, but, I might switch it out with black. I picked up MTA 0300839 fuse block to use on it. I did pick up a 4 Relay/12 Fuse holder, just need to figure where to mount it, most likely in the corner next to the aux battery on that corner bracket. I'm going to re-wire it using the more flexible silicon wires.
I did go the sensor route with the negative cable(used 2AWG). My old man gave me 1AWG red/black welding cable, so used the 1AWG for the positive. I connected some leads to the aux battery so I'm able to plug it into a maintainer, comes out by the bottom front grill.
I left some of slack on the main cables if I need to move/route them. I used 2 fuse, between the isolator and main/aux battery. I ordered some wire loom mounting clips to clean up that side wiring/cabling. Most likely move the fuse onto the firewall for a cleaner look.
427023302_1321708041837625_3864677358337896336_n.thumb.jpg.baabe8cac3e05913787e32e3703a660b.jpg
423944215_1508198366578786_3371667829314448957_n.thumb.jpg.4c876175fef3380f41fe0c2414d872c6.jpg
Don't mind that cable hanging down, it's going to get re-routed, it's for the LED strips.
423944205_737158188389924_1076121781060706663_n.thumb.jpg.cec127cc745a4ab5a627906c28998a4f.jpg
426829811_2636499233182697_3516004806779067301_n.thumb.jpg.30f159e2fca424ba9e2462ec708556ff.jpg
423944256_766047961697091_5723348345559009497_n.thumb.jpg.5c9b4fdab2011139c768ad3c76bbbc7a.jpg
426978189_1026673018437028_5882219932594468394_n.thumb.jpg.344af01aae936d63ca3db6e098895236.jpg
426828269_780489623968849_208218750770543542_n.thumb.jpg.1ea33ba3e6fc1ded6ae1f0139c2ac9d3.jpg
  • 4 weeks later...
Some pics from factory 2nd battery installation. Works fine so far other than first 125 amp fuse provided was actually blown. Replaced it and it's worked solid for over a year now.
Buying the factory stuff was quite nice as it was totally plug and play with not much fuss. Wires fit perfectly and connectors to hold wires just snapped into place. Highly recommend going this route.
I also replaced both batteries at that time with AGM and so far no issues.
  • 7 months later...
Do you have a parts list with part numbers for your kit?
  • 1 year later...
I came across this feed and something similar in another group. I’m looking to do the same if not similar on my 5.3L 1500.
Is this on a 5.3L/6.2L 1500 truck or 6.0L 2500/3500?
the black connector coming off of the grey relay, what does that connector go to? I’ve tried looking up the wiring diagram and have had no luck.
It's been a while since I did this upgrade and don't remember much. I do know though that there were unused OEM connectors in the engine bay and this was just plug and play. Not sure if the extra pics will help. Good luck!
Edit: as per my signature, it's a 6.0L gas 3500HD
FWIW, It's been working well ever since I did it.
I personally would not mess around with aftermarket if I was given the chance to do it again unless for some reason I needed to upgrade the wiring. I have a nice aftermarket sound system installed with 1800 watts (2 Class A/B 900 watt amps at 4 ohm (6 x 150 per channel)) as well but as anyone will tell you the actual amp capacity needed to support even loud listening levels is well below the threshold of the alternator and wiring in this truck. This would be true except for SPL installs - that's a whole other animal. Just thought I'd throw that in there for anyone thinking they can't go with this OEM option as it won't be good enough for their car stereo system.
Edited by eurobound
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
