This is the battery tray, secondary auxiliary relay, and the optional 3 fuse box and cover for older model years if you want to replace the single fuse box on the aux battery harness:
P1140091.thumb.JPG.637d4919ac6459658598cd0667a8e9a3.JPGP1140085.thumb.JPG.1f50169f898eb2767e3c8e96ae9f8f48.JPGP1140088.thumb.JPG.20e911343e0cdbd0563fe85f11d37058.JPG
This is the factory harness between the primary battery and the X50A underhood fuse box:P1010864.thumb.JPG.0343bd904b59b5bf7cf8d6937eedfbe6.JPG
This is the aux battery harness that replaces it and adds the relay for switching the battery isolator, cable running from the primary battery distribution block to the isolator, cable running from the isolator to the aux battery (including the battery terminal with a 125A fuse), the connector for controlling the isolator, and the connector to control the aux battery switching:P1010844.thumb.JPG.de928d415d9aaab933b40255d4a8c19a.JPG
Here you can see the blank screw on the primary battery distribution block - the cable running to the isolator hooks up there.
This is the connector on the aux battery harness where ground, (+), and the control signal (run/ignition) need to get in:
This is the service terminals that connects to that connector. I ran black, violet/brown, red/white wires in the standard flex installation hose along the firewall (connector is on passenger side, my wiring goes back to the driver side)
Here is the battery isolator secured to the firewall. I pulled out the black wire right there to connect to the ground post.
This is the connector where you need to connect the red/white wire from the harness (the terminated lead wire is white)
P1010959.thumb.JPG.152cc71f701d61b424b3f75314a99a8a.JPGP1010960.thumb.JPG.3401ecb312b15e8ad0fdb0acd946204c.JPGP1010950.thumb.JPG.c3982bd7979a619db5ae9085a4590be2.JPGP1010951.thumb.JPG.ebedd8578c7a85278c711eb8e2969285.JPG
This shows where things come together with the red/white wire going to the service connector:
P1010968.thumb.JPG.31eb6682dddd08be84c8ceffa1a07872.JPGP1010969.thumb.JPG.c8398ac358d72afacbe8c849a5233ccb.JPG
Violet/brown can just be tapped into on the engine/body connector:
All done (except for the aux battery which is on order, so I left the cable going to it disconnected from the isolator just to avoid having to heavily isolate it).
P1010979.thumb.JPG.4dee600490e484b0074d282c32205580.JPGP1010976.thumb.JPG.cc70eedad6b064425e1d46d6921185fb.JPG
Edited by Vuk
  • Like 4
  • Thanks 1
What am I missing? Two identical batteries in parallel just doubles the amp capacity and capacitance. Literally acts like a battery with twice the CCA and reserve minutes. So...why isolate and use/charge independently? The alternator doesn't care and the ECU hasn't any idea how big the battery is. So I'm guessing there are other reasons for this???? Educate me...
My first diesel, 91 dodge had one battery. We definitely had it the longest, it just worked out that way. Never had an issue. Two batteries in diesels there after. Didn’t see the point.
Normally it is marketed for the plow guys. They can hook up to the 2nd battery all there accessories and with truck off if truck dies you can start truck. This is why the battery doesn't connect in cranking. It would only hurt the first battery if 2nd was dead.
Ah!!! Thanks.
In fact, ECUs can estimate the battery capacity by keeping track of the discharge rate through the current sensor, which these trucks have. I wanted an auxiliary battery for a 2-3kW inverter, but thought that it would also provide me with a secure start in case my primary battery dies (just of old age because the BCM seems to reserve the right to shut things off if the battery discharges below a certain point).
The fact that the factory fuse between the batteries is 125A explains that the aux battery is not meant for cranking.
Edited by Vuk
Great write-up Vuk.  I only wish my 2018 could use it so I could make my setup OEM like that.  Unfortunately, looks like they've made some changes with the '18.
All the wiring info is from the 2018 builder's manual. The part numbers I got printed out from a dealer, so not sure if the battery tray or the harness would be the same.
Edited by Vuk
Haven't had time to pull the cover off the primary distribution block on top of main battery, but it looks to be different than yours.  I also read in another post, I think, that the '18 changed.  Looks like I have a small ECM on top of my battery, and the cover/charging/jump post looks different.  I'll have to get that cover off to verify.
Could be that it has changed at some point during 2018; I am not knowledgeable enough to say anything about that.
This has my interest. How can a current sensor tell the difference between a 30 amp draw on a 600 CCA system v a 1200 CCA system? Unless I don't understand what is meant by 'rate'.
It guesses. But really it has no clue if there is one or a million batteries. My understanding is it sees voltage and current draw. Nothing fancy just a sensor. And thinks it is low it shuts off circuits. Much like regulating the voltage output on the alternator based on the voltage.
There was a post long ago when we talked of getting the sensor on both batteries so it can learn. But no one tried it. I don't have it and never a issue because vehicle has no clue.
But now you have me thinking. If I grabbed the signal wires and just feed my relay it would work like yours then swap signal wire and the connect on key on. [emoji2962]
  • 3 weeks later...
I picked up a 48PG battery today and installed my three-fuse modification. The original negative auxiliary battery cable 84354708 seems like it would never be delivered, so I picked up 22846471 (at about the same price) and removed the sensor. This one gives an additional ground lead of decent gauge that can be used for accessories, which is even better.
I've replaced the 175A fuses with 250A as a preparation for a 3000W inverter running off of the aux battery. I will post pics once the battery lays down in the next couple of days.
Edited by Vuk
  • Thanks 1
My setup is complete now with nice factory-looking points to hook up an inverter. Should I ever need to jump start the primary battery, I can always run jump cables from aux battery to the primary.
  • Thanks 1
    tararebecca
    tararebecca
  • Who's Online   6 Members, 1 Anonymous, 834 Guests (See full list)
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
