The transmission seem to shift fine, no strange tranny issue that I can notice. Its still under warrenty so I may bring it in but knowing this dealers who knows if they will feel the same thing. They may just say some BS like "thats normal".
The transmission will shift normal if the TCC solenoid is getting stuck or if there's some type of trash in the valve body at the TCC solenoid. This solenoid doesn't have too much affect on upshifts. So this is why you wouldn't suspect a trans issue. There may also be a history code in the TCM they can work on. Tell us what the dealer finds out, if anything.....
Thanks, I'll have to make an appointment and see what they say. Should I even mention anything about a possible TCC issue?
You could hint at it at least. Or make your complaint say something like "it feels like manual trans going to stall without pushing the clutch" any trans guy should immediately start thinking TCC lockup
Justin has a lot of insight and experience and as in recent posts, is on the trail.
My thought is to put it in neutral vs in gear while coasting down. The TC shouldn't come into play in neuchie
Edited by spurshot
Well, I was out and tried this, in neutral it does not do it so, it looks like its a tranny issue. Now to get the dealer to pay attention to my issue and fix it.
Edited by slickman
Made a appointment for this friday so, lets see if I have a fight ahead of me.
Shouldn't be too hard for them, but you never know. Definitely TCC fault going if it's okay in neutral. You may also have some darkened clutches from it staying on as well. Request pictures from the disassembly. Post them here! WE WANT TO SEE!!! [emoji23][emoji23]
Oh and don't forget there could be something stuck in the valve body itself, stopping a valve from moving or maybe a valve bore that's not quite circular. Normally I take a pocket screwdriver and move the valve back and forth easily to see if it moves, it won't take much pressure. If it has to be forced, the valve body needs to come apart. If they are free, checking the TCC o-ring and fitment in the bore is a good idea. If it shudders every time you slow down, then it should be relatively easy to narrow down. If it's intermittent, I would go ahead with replacing the TCC solenoid after the valve body inspection.
Edited by Justin101714
Well, was at the dealer today and a service bulletin was done that they said is what would fix it. So far its MUCH better, it seems to be doing it a little now but I may be overly sensitive so I'm going to give it a week. But right now it seems fixed.
Edited by slickman
I've been having this same exact issue for the past week. Slowing down from from 30 MPH to a stop, may have to make an appointment too. Rotor's and brake's are fine.
  • 3 months later...
What exactly was the service bulletin they performed, I also have a vibration in steering wheel at low speeds.
I've seen a very similar issue on other vehicles when the pinion angle gets out of whack.  Have you done anything that would alter the pinion angle without readjusting it (lowering/lift shackles)?
I have a flip kit and hanger set at 5 in the back. I had a reputable shop in Okc install a two piece driveshaft which fixed the shake vibe at highway speeds and the jump seat doesn’t shake anymore, but the steering wheel vibe is still present at 20mph. It’s funny it doesn’t do it all the time, so I don’t think it’s driveline related. I’ve had the tires balanced several times at different shops, just had an alignment done that helped a little bit.
I am having a similar issue after installing 2.5" rear lift blocks and a set of Bilstein 5100 set to 1.85". Feels like bad shake while braking, felt through pedal and stearing wheel.  Starts at around 70kmh very slightly worsening as I get closer to 30Kmh.  I believe my problem is pinion angles do to the wrong style block??  (all installs were done by a shop and it did receive an alignment. Also has been back and everything checked over)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
