Issues after installing CAI
romanzo
I installed the airaid 200-285 CAI on my 14 Silveradoo z71 this past weekend and have noticed the truck running a bit funny since. First thing is the truck seems to be a bit sluggish, especially after moving from a stop, or letting off cruise control and hitting the throttle again. It seems to get caught in making a louder than normal "BURRR" sound when barely hitting the throttle during city driving/stop and go. Usually if it I really press down on the throttle it works through this. The biggest thing I noticed today though was how loud my fans were running. I started her up this morning and the fans were kicking hard, they ran like this for my whole hour drive to work.
Some of my guesses as to what could be wrong include a dirty MAF sensor, either from previous use, or possibly from the filter not being oiled enough. The company I bought it from said it SHOULD have a light oil coating on it when it comes. But I think it could be underoiled or not oiled at all, it was hard to tell when I installed if it was oiled at all. Or maybe there is a leak somewhere which is causing this. This was one of the first mods I've done on my own so it is very possible I did not install something correctly.
Any help/suggestions on what to do would be greatly appreciated. Thanks!
I second the motion..
MAF sensors do not like any oil residue or dirt..
Recommend cleaning with MAF spray and replace "Wet" filter with "Dry" type..
You may need to clean pipe from sensor to TB just in case oil particals were left in runner..
Also,, check TB for oil...
Cheers---K
Too much oil possibly trashed MAF?
BTW already has CAI paper filter w/o oil FTW.
It is posssible, however like I stated before I did not oil it at all, and it did not feel oily when I received it. I feel like if it was over oiled you would be able to feel some oil somewhere on the thing. This thing felt like it was not oiled at all.
Cheers---K
Thanks. I will try to clean the MAF today and check around for oil.
Just because you didn't feel or see oil doesn't mean it still wasn't over oiled from the factory. They do try to get them out ASAP so mistakes can happen. I had a K&N intake kit on my '98 and the MAF sensor did need to be replaced, but it was years and years after installing the K&N so I don't think that was the reason. I honestly don't know if I would get another intake kit, or at least one with either an oiled or dry filter. Especially with these new trucks with all of the sensors and electronics. A dry filter makes me believe that it's not filtering as good as it should since it apparently gives the same performance as an oiled filter without the oil. So the only way I can figure it does that being dry is that it has bigger openings for dust and whatever else get through.
When I had my '14 all I did was get the Airiad MIT, so all it did was replace that big ass intake with a single tube and it allowed me to keep the factory filter box and filter. Plus it helped that it was half the price of a full intake kit.
The K2s already have that problem of the engine oil going through the intake so you either buy an oil catch can or deal with the problem through out the life of the truck. So why possibly add more oil from the aftermarket oiled filter.
Would the truck not throw a code if it was a MAF issue? They say to disconnect battery before you pull the MAF to avoid CEL. My 07 Dmax at work did that after a new oiled filter. I hit the MAF with SensorKleen, cleared code and she was happy.
no more k&n filters went with aem dry filters have not looked back
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
