Picked up a 2017 Summit White Crew Cab LT with the 5.3 and E-assist. Nice having the extra ton of tow capacity and seeing around 22 MPG in mixed city/highway driving. I believe it is only available in California, Oregon and Washington.
It has some quirks with auto-shutoff at stop lights and the batteries on the floor under the rear seats.
Having difficulty to find any storage that will fit under the rear seats. Anybody find storage that works? At the lowest it is down to about 5".
Welcome to this forum! I am interested in hearing more about your experiences with your new truck. I came very close to buying a hybrid Sierra 1500 in 2009. I think this is a great power option for the type of driving I do but is no longer available where I live. I have a locking aluminum box in the back of my truck to keep all of the "stuff" I want in my truck for emergencies or occasional usage. I like to keep my back seat area clear of junk. There is plenty of storage up front for the items I need to keep close at hand!
Awesome! THis is something I tried to buy but was given the runaround and no deal to get it?
I fully expect GM to continue this and add dynamic fuel management with improved batteries and hardware etc. I am looking for the 5.3L to be bumped up on HP/Torque added 10spd and dynamic fuel management system and putting the MPG's numbers something like 20 city 26hwy.
I like this over ECOBOOSTS any day!
The hybrid trucks are mostly for city driving fyi.
There sole purpose is to basically regenerative braking, to capture all that energy we use slowing down.
If you're cruising down the highway, I doubt there would be much of a difference in fuel consumption.
Yes, they were originally pitched that way for city/haulers etc. Yet they net 2mpgs better on Hwy?
The system was intended for validation and technology before they up their game on next gen....I can guarantee you GM wants the coveted MPG crown for half-tons and using a V8 gasser over the ecoboost is icing on the cake! Never mind diesels not talking about those........
Agreed, I see the most benefit driving in the city but there is a little benefit on the highway., Only have 250 miles on it so far so we'll see how the MPG numbers hold up in the longer term.
The highway numbers come from eco tires and a nice big air dam. The hybrids from last gen were way too low to the ground.
I have a 2016 LT e-assist 5.3 wth 8 speed transmission. 13000 miles and no complaints except for the bolt falling out of the brake caliper bracket on the front right wheel, damaging the rim. All remedied under warranty.
I installed the GM version of the rear underseat storage compartment last night. Fit perfectly and operates as designed. Although a little pricey.
https://www.amazon.com/Accessories-23183674-Underseat-Storage-Compartment/dp/B0199WFB3A
I'm not sure if the "hybrid" battery placement changed for the 2017 models. If I remember correctly, mine is located under the center seating position of the front seat. If GM did relocate it under the rear seat, that would present a challenge with storage options.
Reviving this topic. I've picked up a 2017 E-assist CCSB here in Texas. Texas Edition w/ 3.08 rear, 8-speed, 5.3L V8.
I was planning on transferring my AirRaid MIT tube, but come to find out the engine bays are different for the E-assists.
See pics below. Someone else chime in if you have some info. Looks like they relocated the radiator fluid to the front, revised the intake, and put the lithium battery beside the stock battery. The MIT tube hits the radiator fluid and doesn't have enough room to connect.
I'm told I can jump my stock battery with the lithium battery if my truck ever dies, pretty cool there. Hands down rides 10x smoother for some reason, the shifts are like butter compared to my old BBP tune.
Tires, wheels, tint, and clear bra for the hood/fenders come in on Thursday - exhaust will be installed back on next week. Fox 2.0s are back on with the BackFlip MX4. Kicker setup is back in as well.
Talk about a long weekend.
Edited by ChevyRoofer
Are you sure 8speed? I was under impression the 6speeds were for Eassist?
Yep, they definitely are the 8 speeds.
Thanks, I Like it much! I tried to get a 2016 to much of a hassle......What are your current MPG's
I hope they further the technology on the Next Gen
Averaging 21 around the city, haven't driven on the highway yet.
Picking up heavier tires tomorrow so that might change my MPG a little.
And I do too.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
