Engine cover...Done!!
Finally got my engine cover back!! I had them paint it Cyber Grey Metallic like the Vettes paint code
I love it 95f818f5752d85e4ed8da75804fd18c7.jpg3acb2aa5af5f3e3ca546a0181fc852c7.jpgf3aeb1a767d47ec0c974a4393551fb69.jpg
looking good , maybe a installed photo . where did you get it , maybe the part's number . please
Looks good... Inspiring me to look into this under-the-hood mod!!
Sent from my SM-G955U using Tapatalk
i'd do this mod.. need to find a white one . with GMC on it.
that's a sweet color too
I always give my camaro friends who have this color crap since they discontinued it in 2011. Only lasted 2 model years. AGM lasted from 2012-2015
Looks great! I truly appreciate hidden mods like this. I wonder if this would be available or adaptable for the 4.3? I think chrome would also look good.
Sun isn't in the right spot yet to shine on the cover while under the hood but this is what it looks like 248d5e472d5062d129e3450b22dad84e.jpg6c3057f45f7515ce732b6130aff60cf1.jpg
looks nice. I had someone paint my engine cover for my Camaro. Once its under the hood, it just doesn't "pop" like it would under the sun.
Looks good. I see the power wire wrapped in blue as well. You have an upgraded audio system? Y'all gonna make me paint my engine cover as well; I'm thinking red
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
