Low oil pressure
Hi all,
Here is where I'm at.
2003 Silverado 1500 hd with 6.0 l 275000 km , engine sounds good, no knocks
Low oil pressure 6 lbs confirmed with mechanical gauge right from where oil pressure sensor is located
Changed oil ring on pick up tube, dropped pan, cleaned pick up tube, changed oil pump, new oil pressure sensor.
STILL low oil pressure!!!
Please help. I'm out of ideas....
Oil pressure is determined by pump and bearing clearance you engine is most likey shot cam bearings and main bearings shot Could easily lead to little to no oil pressuee
^^^^ This. You probably have just enough oil supply to keep an oil film between moving parts for now
Some more info
Tested this morning with manual pressure gauge
Startup engine cold 15 psi
Warming up idling pressure slowly drops to 6.5 psi
Rev to 1000rpm- 12 psi
1500 rpm/ 15psi
2000 rpm/ 20.5 psi
2500 rpm/ 25 psi
3000 rpm 32 psi
Back to idle 6 psi
So the only time there's low pressure is idling after warmed up or foot on Brake when in drive
Thoughts?
The oil pressure system is not real complicated. If your motor is worn out, its worn out. Try a different filter and a heavier oil. Not much else you can do. Drive it till it dies. If/when the motor throws a rod, put a used $150 engine in there from Pick'N'pull and cruise on.
Did you swap in a high volume pump? That might buy you some more time, but it sounds like it's tired.
Sent from my SM-T350 using Tapatalk
You can run thicker oils such as Mobil 1 20-50 and start saving money to do an engine swap. With those pressures, the bearings are worn and the only way to correct is either installing a high volume pump like sdeeter19555 mentioned, or rebuilding the engine.
If the pick up tube o-ring is the wrong one, installed wrong or something being wrong with it, it will also cause low oil pressure. What oil pump did you replace it with? Often times, new items can be faulty too.
Versions of these engines had a screen inside the tube the oil filter screws into - a safety measure to ensure a failed/blown filter wouldn't spew junk into the engines.
Sent from my XT1053 using Tapatalk
In my part of the world, you can buy a used motor from PickNpull for super cheap. Comes with a 30 day - or for a couple bucks more you get a 13 month warranty. You should be able to get a local Craigslist mechanic to install it for $350-$500. Total cost should be between $750-$1000 including new plugs, sensors, fluids etc. Just make sure the motor comes from a vehicle that was obviously in an accident, and run a compression test on it before you pick that particular motor.
300-D Engine Diesel Long Block Car $248.39
300-4D Engine Diesel W/Access Car $269.99
300-4F Engine F-Inj W/Access Car $169.99
300-2 Engine Long Block Car $149.99
300-1 Engine Short Block Car $129.99
