6l80 1-2 hard shift
apollo18
i got a 2007 escalade with a 6l80 (still gm ahah). the transmission was replaced about 180km ago. the truck right now has 320,000km on it.
The transmission has a problem and its had it for a while. the transmision was put in brand new around 2010/2011. The problem has been happening for atleast two years and its annoying. I hate taking it to gm because they charge a ton and then just tell me to replace the tranny.
Now to the problem:
The truck has a hard 1-2 shift, and a semi hard 2-3 shift. The 2-3 shift is ok. I only have a problem with the 1-2 shift. The truck basically thuds into a shift only for the 1-2 shift. The 3-4,4-5,5-6 are SUPER SMOOTH. its a 6l80. I had the fluid changed a couple times, that didndt fix it. I just got the whole fluid flushed with a new filter and that made the shift a little more smoother but the 1-2 is still a thud. What i noticed is that when I have the battery unplugged And then I plug the battery and drive. The transmission shifts smoothly. Last time I had to unplug the battery and drove the truck after i thought the problem was fixed but it came back after a day or two i cant remember. The 1-2 shit is hard no matter what, even with WOT, or manual or slow speed. I read around and i thought it was the TPS so i replaced that. No go, also replaced the MAF to fix a engine code, and then I read around and some people said Camshaft position sensor so i ordered that and will put it in once its here.fluid level is fine in the truck. Other then the 1-2 hard shift, the truck run's fine. i just wanna fix the hard shift. I believe its a sensor or something electrical because it seems to go away when teh truck has no battery. but then it comes back after a day or two. The 3-4,4-5,5-6 shift is ALWAYS SMOOTH. once again the 2-3 shift is bearable its a light thud but not that noticeable so im happy with it.
Truck has stock ecm and tcm. Here are some codes I pulled a couple months ago from a bully dog. Maybe they will help?
P2700 Transmission Friction Element A APPLY Time Range/Performance
P0100 Mass or Volume Air Flow Circuit (should be fine now after MAF change)
P0500 Vehicle Speed Sensor A
P0200 Injector Close/Open
P0700 Transmission Control System MIL REQUEST
P1500 Vehicle Speed Sensor VSS Intetermittent
and then a bunch of unknown ones too
any help?
thanks
I think you need a transmission guy with those codes. However, that Bully Dog pulled some non existent codes. The only two codes that came up in GM service docs were the P0700 and P0100. Need a much better scan/code reader.
Take it to Advance Auto, they have a pretty decent code reader and scan for free. They won't get them all, but they get more than the average code reader.
If your ISS and OSS don't correlate. You will have line pressure issues. Basically the TCM is defaulting to higher than normal line pressure because the input speed sensor and the output speed sensor aren't meshing quite well. Could be multiple causes for this. But, what I do to verify speed sensor operation is use a variable signal generator at the harness connector the sensors and see if the scan tool data is responding to the change in signal. This would verify if the sensor is bad or if the TCM is bad. You could also have a circuit issue between the TCM and the sensor.
my bullydog has always been iffy with finding codes. sometimes it displays them sometimes it finds none. i tried with vehicle off, vehicle on, key in run and it didnt show anything. i tried two days in a row. so then i went out and bought a autolink al419 but this code reader only shows me two codes that i dont really cara bout
P0308
P0455
i restarted truck and tried twice but only two codes. I usually get way more on bullydog(when it works) and bullydog is where i got the VSS one. This code reader was $150 CAD should be good enough.
I dont have any advanced auto or o reillys here so i cant get them to check codes.
What i did is erase the codes tho and ill unplug the battery and then check after a couple days to see if any come back?
So when I first scanned codes last week I was only getting two codes
P0455 which I've been getting for like 2 years
P0308 I've had this for a while as well
I then unplugged the battery for a couple mins and the shift improved a lot, it's just a slight thump! Then after a day or so, it went back to the hard shift.
Over the past couple days I've tried to scan codes again with both my bulldog and al419. The bullydog isn't showing anything and the al419 only shows
P0308
And p0455
Do I need a better scanner? My bullydog is a hit or miss, when it does finds codes it usually finds a lot
got a gm mechanic to look at it, he reset it with tech 2 and now its smooth as butter. every single shift. hes gonna look into the codes and let me know.! seems like its gonna be a small problem/sensor since it went away temporarility with a reset?
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
