AFM not working at higher speeds?
GMcD
I have had my 2014 Silverado about 5 weeks and love it other than a paint issue (currently getting repaired). On the way to take it to the body shop (4.5 hours away), I noticed that my truck rarely dropped into v4 mode. It didn’t matter if it was flat or down hill, it wouldn’t engage. This was with cruise control on. After watching it for the next hour or two, it seems to work with the cruise control off. I also noticed that if i get to my target speed (say 78mph), that if i enabled cruise with v4 mode on, v4 mode was more likely to activate with cruise control on. Is this a known issue and if so, whats the fix?
I turned mine off. In your case the higher the speed the more wind drag less V4 mode.
If you set the cruise at 60 mph on flat terrain, it should stay in v4 most of the time.
Truck is fighting way too much wind at 78 mph. If you are driving 78 mph, I'm guessing fuel efficiency is not your top priority.
I agree.    Not a problem.  Mine works on cruise control at 60 mph.
Cylinder deactivation may be inhibited for many reasons including the following:
Engine coolant temperature out of range for cylinder activation
Engine vacuum out of range
Brake booster vacuum out of range
Transmission gear incorrect or shift in progress
Accelerator pedal out of range or rate of pedal application to fast
Engine oil pressure and temperature out of range
Engine speed out of range
Vehicle speed out of range
Minimum time in V8 mode not met
Maximum V4 mode time exceeded
Decel fuel cutoff active
Reduced engine power active
Torque management active
Catalytic converter over temperature protection active
Piston protection active, knock detected
Cylinder deactivation solenoid driver circuit faults
V6 or V8?
Good info. Where did you come by it?
My truck is a v8. Wind resistance does make sense as well. Ill try 70mph next time and see what happens. Thanks
  • 2 months later...
New member - this is a great a great forum.
I just took delivery of a 2018 Silverado with the 6.0. I was disappointed (at first) that it did not have AFM. I had rented a pickup with a 5.3 and really enjoyed the fuel economy and was looking forward to it on our 2018. But after joining this forum and reading some of the horror stories, I am glad it is a straight up 6.0.
I traded in my 2005 2500 with a 6.0 and the engine still ran great but was developing low oil pressure only on start up. With 300K miles, I guess that is a fairly well known issue. A crate motor would have been around $6000 and we just decided it was time to replace the old girl.
Question: does anyone know why this truck has a 2.5" receiver and then they give you a 2" sleeve?
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 561 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
