I purchased a new 2017 Silverado this past March. After about 3000-4000 miles I started to hear this clunking/ popping noise in the rear of the truck. I took it to my local dealer twice and they said they lubed the leaf springs. Didn't fix anything. I then took it to another local dealer who said the noise is coming from a leaf spring schackle and they think they got rid of the noise. I drove it for a few weeks and didn't hear the noise once. Right around the 3 week mark I started to hear it again so I took it back to the dealer. This time they said they lubed the leaf springs but this is only a temporary fix. I was understandably upset considering this is a brand new truck and it should not be having this issue. I did some research on this and found that some people had the springs/schackles replaced and it corrected the problem. The dealership said they will not replace anything until a permanent fix has been sent out by GM. So I called GM to complain. They basically told me the same thing. I am not happy driving around a truck that sounds like it's falling apart in the rear end and GM won't do anything about it. They won't even make the effort to replace the part to make the customer happy. Has anyone had this issue? Any advice on what to do or who to call and complain to get this issue fixed? Any advice is greatly appreciated. Thank you!
That appears to be gm’s response to every problem since 2014s rolled out. Just left dealership where they told me I had 4 ball joints out, needed new pads and rotors, and my transmission fluid smelled “burnt”. Went to local shop and said it all looked good. I had just had the brake pads change so I know they are crazy on that one. Will likely get trans fluid changed as I’m at 55k and I’m about to do the tcase and diffs. Sad
Tons of us have had this issue. I used the bicycle inner tube trick to get rid of my issues.
How would I do the bicycle inner tube trick? I assume you cut it up and put pieces in between the leafs springs? Please let me know where I would put the pieces to eliminate this noise. I'll try anything at this point.
One question though, the dealership said the noise is coming from the rear schackles not the leaf springs themselves.i can't picture how inner tube pieces would help stop the noise in the schackles. Again any info is appreciated. Thanks!!
You are exactly correct. You cut it into strips the width of the spring. Jack the truck up to relieve all pressure on the suspension and then take a pry bar (I wrapped mine in a shop towel) and pull the spring apart ever so slightly and slide it in. Do this for all contact points. It helped mine tremendously. The shackles I am not sure on. I still get a slight thump when I slow down fast on a decline, but it is very rare and I just dont notice it anymore. I went the route of the dealership (I bought certified pre owned) and got the same run around as you are getting. I got frustrated and did the inner tube trick and it has worked out for me. I honestly do not think GM will release a "fix" for this minus packing the springs with so much grease it is ridiculous.
1 hour ago, troop12 said:
Ok thank you. I will give that a shot. GM claims they are currently working on a fix for this noise but they couldn't give me a time frame so I agree with you that it will never happen. It's too bad because I love this truck but I don't like doing business with a company that knows there is an issue with a part and refuse to fix it no matter how big or small the problem is. Thanks again. Any other info and suggestions are appreciated.
Just like sippisierra said, cut 1 3/4 or 2 inch just measure the width of the spring and I think I cut mine 2 1/2 length wise. Place them in front and the back of the middle spring. While you have it jacked before applying the rubber, clean out all the old grease so dirt and stuff don’t stick to it.
Did you end up trying the innertube? Curious to know if it helped your issue
Yeah I’m pretty much frustrated with GM right now. I have a 16’ Double Cab GMC Sierra, that has already been in the dealership for a malfunctioning cadalyc converter around the 1st of October. Maybe 2-3 weeks later I hear a clunk sound coming from the rear. And last night while driving I heard a sound coming from where the transmission and driveshaft meet I’m assuming.
If it wasn’t such a pain in the azz to get a loaner vehicle from my local dealer I wouldn’t be pissed, they constantly give me the run around about how I would be the 16th person in line for a loaner, wtf?
Also so where I live in Huntsville  a small Tx town with bumpy roads, this sound doesn’t keep me assured everything will be okay.
I did end up putting pieces of a tire inner tube between the leafs and as far as I can tell no more noise. Thanks... Still wish GM would fix it properly though.
  • 6 months later...
I have bought two 2017 GMC 1500 Denali's 4x4 and both have the rear end noise everyone has been describing on this thread and the others.    I have a 20 year old truck at my ranch an it is quiet than these new trucks, very annoying.     After about 5k miles is when I started hearing it on both trucks, on one truck dealership tighten leaf springs and that helped for about 30 days.   The dealership keeps telling me its the floating axle in these trucks and that is just the way it is and cant be fixed.     I cant believe GM would want to build a truck with this type of noise in rear end.
Maybe  the only way to get satisfaction is to bring a class action suit  since this cant be right, seems to be a very consistent problem, so likely a lot of us, everyone's getting a different story, etc..    I happen to know some guys that do this type of work and will discuss with them.  Stay tuned.
M,
pictures would help thanks!
I have a similar issue. I have a 2017 double cab sierra 1500, which has developed a rubbing noise in the rear driver side. It sounds like metal rubbing against rubber. It can be easily replicated when I push the bumper down by hand with the vehicle stopped. Not sure if this is the same as your issue.
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,450 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
