Things to go with a spindle lift
Almboss
So Im going to be keeping an eye out for a spindle lift over the holidays hoping to catch sale one one. Have not determined what brand or how much of a lift. Im thinking 3-5" on lift. If I happen to find one I like what else would be good to replace or upgrade on the front end since Im going to have it apart.  Any feed back on spindles is greatly appreciated as well any other parts.
New shocks, rear blocks. Assuming you have 2wd?
Yeah its 2wd.  Thinking of leaving the back as it is. Right now it have a 2" level spacer on the top of the strut not sure if i want to leave it or just take it off.
I did a 4.5" maxtrac spindle and ProComp ProRunner SS adjustable struts in the front with a 5/34" Rough Country anti-wrap blocks and ProComp ProRunner shocks in rear. Well worth it honestly. The truck is stiff, doesn't squiggle and can take corners keeping planted.
I have an extra set of brand new BDS lift Spindles for a 6" lift kit.  They accidentally sent me an extra set and said to keep.  Would these be worth anything?
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
