53 minutes ago, redwngr said:
They've been like that on Canadian ones for many years.
I've learned to live with it.  A vehicle without daytime running lights looks unusual around here now.
And of course the auto function will switch the daytime running light to regular headlights and taillights when the light sensor detects dusk (or inside a tunnel)
I've heard that the switch can be taken apart and the spring removed so that the knob will stay in the 'off' position.
Could probably also by the US knob from a dealer or parts house.
I’ve seen the video your talking about but I figure if they won’t turn off when I hold the switch in the off position then it wouldn’t matter if I took the spring out. The only reason I’ve been trying to turn them off is because I’ve been having a problem with the HID’s I’ve installed and I’ve been told to disassemble my DRL’s or just turn the lights off and obviously I can’t do that with my truck. Maybe I should just switch over LED’s and get rid of the problem.?
  • 3 months later...
Just added the diode on my truck and I love it! Great mod!!!
On ‎6‎/‎15‎/‎2019 at 12:51 PM, AX633 said:
Boost auto parts sells a part for this. Simple and works flawlessly
Do you by chance have a link or anything?
  • 5 weeks later...
On 2/26/2019 at 5:25 PM, Swerve-n-protect said:
Ok, just to make sure..... the Diode circled as #1 is for the "fogs with parking lamps" mod and the diode #2 is for the "LED lights in the mirror come on when in reverse" mod, correct??  thanks!!!
Just did this to mine yesterday...  Thanks. Works great...  Although I have the boost fog light wiring  (was installed on another truck before I sold it)  I just used the diode this time around...
And if anyone is curious the speed turtle light flasher module still works with this mod...   https://www.ultrabrightlightz.com/flashers/
I think I can help you solve this problem. Regarding the problem of LED conversion, because we have been engaged in LED lights for many years, we can provide you with good suggestions. Please describe to us in detail the problems you are currently encountering, because Your current question is too general, I cannot know some details. Of course, if you want to replace them directly, you can take a look at our LED grille lights, which may be helpful to you
I have a 2016 silverado ltz just purchased. I cannot get the lights to turn on. I Hit the cargo light switch and the lights in the bed turn on but i cannot get the side view mirror lights to work in park or reverse.  Is there a fuse i could check?
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
