Power Steering Filter?
notice a puddle of power steering fluid this AM, coming from this part (back half split open) Anyway, I guess this is a filter for power steering?  Is this even needed?
2000 Silverado
I went ahead and broke it all the way open, it had a little screen inside of it. So I have to assume it's is a filter
Sent from my SM-G930V using Tapatalk
I replaced it filter.. it's all good now.   I guess it was the cold that made the back piece split open like that?  not sure, but it looked like a pretty new filter (truck is new to me)   it was around 20 degrees this AM when I cranked it up.
Typically on aftermarket pumps they sell versions that call for or come with a filter.  They have a label in the boxes, usually Cardone reman units or ones from the same remanufacturer, the three F's, Flush, Fluid, Filter.
The 3 F's  https://cardone.com/tech-help/steering/how-it-works-best-practices/3f-fluid-flush-filter
Inline filter  https://cardone.com/products/steering/steering-products-remanufactured/magna-pure-power-steering-pumps
apparently all those little in line power steering filters have bad reviews... whether plastic or metal. People complaining about them breaking apart under pressure when cold...exactly that happened to me.
I'll be removing it  here shortly... and just run without a filter.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
